Originally Posted by Vanexel711
Hi everyone,
Got my projector this week, and am having some issues:
1. It always looks like the projector needs to be rotated a few degrees, as if the picture is not leveled and even. Like, I can get the left side perfect, but the right side droops a little lower. I'm assuming I just need to adjust the feet at the bottom. Is this normal?
2. Just got a DVD0 Duo, and Chromapure. I'm totally lost how to use this thing.
I can get autocalibration started and running, but once the tests are done, does it save the calibrated settings to the DVD0?
Also, where should my i1display be positioned when taking the readings?
All I want to do is get this sucker calibrated for watching 2D blu rays. That's it!
Any information would be helpful to me. Thank you.
Hi everyone,
For question 1 above: you need to use a level to make certain the projector is absolutely level both left-to-right and front-to-back. Also the projector must be "squared up" with the screen. By that I mean the front and rear surfaces of the projector cabinet must be parallel to the screen. The problem you are having is typical when you have not properly leveled and squared up the projector. Only after you have done the above then turn on the projector and use vertical and horizontal lens shift and zoom to center the image on the screen and to set the image size to fill the screen. Do not move the projector in an to attempt to center the image
As for getting started with calibrating your projector: a good starting point is to read the calbiration for dummies guide - HERE. Its somewhat dated and doesn't specifically cover the ChromaPure software but it has a lot of excellent information on calibration. Also see the thread I started a year ago on calibration of the RS40/X3 projectors - HERE.
![Disney WOW: World of Wonder [Blu-ray]](http://cdn.avsforum.com/d/da/50x50px-ZC-dadc69a0_B0045ASBLG-51TziBcqZFL.jpeg)
I thought these were going to be gone in a few days.
