AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › Official JVC RS40/X3 Owners Thread
Official JVC RS40/X3 Owners Thread - Page 314
post #9391 of 9680
Guys, do I have the latest firmware version for my X3:
main: 201010291
sub: 2010.12.14.2-O
switcher: 2010.10.19.1
DD: 0A0F0A
driver: 4300
post #9392 of 9680
Originally Posted by coderguy View Post
The motion isn't the best, but it's generally ok and you get used to it.
Could someone give me advice on motion management. I try the various settings and have a problem seeing much difference. Also, I have never seen the so-called "soap opera" effect. Does the motion control only work when showing film? Golf balls, football passes, baseballs don't seem to change in motion when I set to various stages. Perhaps I am not executing the effect properly.
post #9393 of 9680
CMD Mode 3 is the one that is recommended to use. You will notice more SOAP OPERA effect if watching a movie in 24p with it enabled, then if watching Sports @ 30(60hz), but the difference is still there. You should notice a slight smoothing effect in either case.
post #9394 of 9680
CMD Mode 1 and 2 are for 60hz only and will produce lots of flicker if you try and use it when you are sending a 24hz signal.
post #9395 of 9680
BTW, welcome back to the JVC club, the JVC was also my first sharp 3-chipper and it is very nice having a 3-chip projector that is this sharp. It is almost like having a DLP with a slightly flatter image that is about as sharp. I can still tell on certain scenes DLP can pop more even over a very sharp LCOS, but just as many other scenes favor LCOS (not just dark scenes either).
I bet if you watch the right movie, you will notice the JVC is actually quite a bit more contrasty in dark scenes than the Marantz even though the blacks might not go a lot darker, but I know the Marantz was one of the best DLP's at this as well, so...
Edited by coderguy - 10/14/12 at 8:51pm
post #9396 of 9680
Haha, I know, I know. But I really did want to give JVC another chance. This is the sharpest 3 chip projector I've ever owned and I'd even go out on a limb as say its sharper at normal seating distances compared to .65" DLPs. I think that has a lot to do with my particular unit and its unusually nice convergence/lens. I'm very impressed. I also purchased an emitter and 3 pairs of Xpand 3D glasses. The 3D is a nice add on and is very well implemented. Though, I've only owned one other 3D projector (Mitsubishi HC7800D) which wasn't the greatest at 3D even though it was a DLP. There was flickering and ghosting. The JVC is on par I'd say. Black levels seem to be great and about equal to my Planar PD8150. Though on a totally black screen the JVC goes a tad deeper.
post #9397 of 9680
Could always change tagline to:
You buy an Epson when you want to be somebody, you buy a JVC when you are somebody.
Above stolen from RovingTraveler's tagline about buy ferrari, buy lamborghini...
Actually you buy a Lamborghini when you want to get car-jacked...
(and no I would never really put that in my signature)
Edited by coderguy - 10/14/12 at 10:18pm
post #9398 of 9680
I'd be quite the hypocrite if I still had that in my signature. I still do favor my Planar for many reasons and will continue to use it for certain material. Darker material for sure on the JVC. For instance I was checking out a few scenes from the last few Harry Potter movies last night. These are some of the darkest movies ever filmed. They looked fantastic with the JVC.
With that being said, while this JVC is great, I still think higher end DLPS like my Planar are much more well rounded. But you have to spend the big bucks if you want that kind of performance. JVC projectors offer some of the greatest 'bang for the buck' out there.
post #9399 of 9680
I also use different projectors for different content. I watched "Chernobyl Diaries' on Saturday night with the RS55. None of the under 10k projectors can come close to replicating this level of black detail, 1/2 the movie is shot in the dark and it wouldn't have had the same impact on lesser performing models. Drop to black = lights outs which adds to the fear of this movie.
post #9400 of 9680
Hey guys, can someone recommend a neutral density filter for my RS40? Currently I am projecting onto a 110" diagonal high power screen. I have the lamp on normal and the lens aperture at -15. Bulb only has about 15 hours on it and overall it looks great, but I need to tone it down just a bit more if possible until the buld dims further.
I know about them, but I have no idea which one to get and if there is a size that will just clip on or I have to rig something.
Edited by NateTTU - 10/15/12 at 6:04pm
post #9401 of 9680
I used to have a Hoya HMC ND2 filter myself as I found cheaper plastic ones caused odd reflections back into the projector which really lowered ANSI contrast. I don't know what size you would need, but I used a 77mm on an older Panasonic and used a small amount of BluTak to hold it in place.
post #9402 of 9680
How many mm is the RS40 lens?
post #9403 of 9680
Where can I buy a genuine replacement bulb for RS40 (It cannot be ebay)? I tried to search online but most of the links are about bulb problems, not where it can be purchased. Thanks.
post #9404 of 9680
Have you tried Mike at AVS?
(585) 671-2968
post #9405 of 9680
Originally Posted by mbw23air View Post
Went to turn on my RS40 today and no go. I had to point remote at back sensor for it to work. Put in new batteries and even checked to make sure code wasn't changed as mentioned in earlier post. Crap....I need the front sensor to work as I use it religiously as I have both a 2.35 screen with an anamorphic lens and 1.78 screen and remove the A-lens for the 1.78 screen and have to zoom, shift, and refocus. Looks like I will be contacting JVC.
Mike
Same problem with my RS-40: only if a leave the ac power disconnected for a day, front sensor works, but only for half an hour then only back sensor still works.
I've contacted my reseller and he says that may be a problem with the control board.
Luigi
post #9406 of 9680
Luigi
Luigi,
Thanks for your response. My RS40 is still doing this but then when I unplug for a while and replug power cable back in it then works so it sounds like we have exactly the same problem. I have a RS4810 preordered so if my finances are ok to get it when AVS calls me I will just wait till then to send my RS40 in to be repaired under warranty as my warranty is good until April 2013. I don't wanna be without my RS40 as I have several movies I am ready to watch.
Mike
post #9407 of 9680
I'm in the same position, my warranty will expire december 2013, until then i need to find the courage to stay apart from it for at less 15 days.
A good solution until then may be an external Infrared sensor, if anyone know a 3,5mm jack Ir sensor compatible with jvc projector, i'll appreciate that.
Sorry for my poor english.
Ciao
Luigi
post #9408 of 9680
Originally Posted by 34" url="/t/1296327/officialdojvc-rs40-x3-owners-thread/9390#post_22498226"
I just got one from JVC directly on 10/15/2012 couple days ago, unused. (have the order invoice) It is the latest one with a flapper inside. We can talk if you have any questions.
[/LIST]
post #9409 of 9680
last attemt:
main: 201010291
sub: 2010.12.14.2-O
DD: 0A0F0A
driver: 4300
post #9410 of 9680
Originally Posted by sanderdvd View Post
last attemt:
main: 201010291
sub: 2010.12.14.2-O
DD: 0A0F0A
driver: 4300
I replied in your other thread that asked this question. You have the first update to the firmware that was released shortly after the X3 began shipping in late 2010. You should update to the current version.
post #9411 of 9680
Ron,
What is the latest version?
post #9412 of 9680
Originally Posted by JackB View Post
Ron,
1.5
You can download it here:
http://support.jvc.com/consumer/product.jsp?archive=true&pathId=140&modelId=MODL028777
post #9413 of 9680
1.5
I have the RS40. Does the X3 firmware work or do they have a seperate version? I think I know the answer but just want to be sure. Also, the inquiry above's numbers don't show anything that looks like 1.5. What am I missing there?
post #9414 of 9680
It's for both models. It says so in the installation instructions.
post #9415 of 9680
Can somebody please post a correct model number for RS40 replacement bulb? I would like to but directly from JVC but cannot find it at the JVC website. Thanks.
post #9416 of 9680
http://pro.jvc.com/prof/attributes/accessories.jsp?model_id=MDL102022&feature_id=05
Item #: PK-L2210UP Replacement lamp for DLA-RS40/50/60 MSRP: $499.00
JVC sells them direct here:
http://store.jvc.com/product.asp?Model=PK-L2210UP
Edited by Seegs108 - 10/19/12 at 7:19pm
post #9417 of 9680
Today, I turned on the projector and got lamp light (middle light) blinking in orange and other two lights staying in red. I am not seeing projector illuminating the screen. What does it mean? The lamp cover is not all closing. I tried pressing standby multiple times and it does not responding. Only after disconnecting power chord and then connecting it, I see standby getting on. Then when I press projector "on", it is again taking to middle lamp indicator blinking orange and other two remaining red.
Two days back, we noticed picture is little dark. However after increasing brightness little more, we were able to watch. It is only 950 hours. I also don't turn on/off frequently. I leave it on if I take break for 20 or 30 minutes. It is ridiculous to find that lamp is not working just after 950 hours. I remember seeing it lasts for 3000 hours. I am not expecting 3000 hours. Why not even 1500 hours.
If I call JVC, do they prorate at least to reduce the price of the bulb. I will call tomorrow. Appreciate any input. 400 dollars is too expensive for me to replace.
post #9418 of 9680
If you don't get an image, your lamp has failed. Call JVC customer service to see what they can offer.
Ian B
post #9419 of 9680
Does the RS40 series have the same dust issue like the older JVCs where after about a 1000 hours you have to open the back to remove some dust with a cloth?
post #9420 of 9680
Start about 1/3rd the way through this thread and you will see what you are faced with. Common problem. Hope you are under warranty.
