AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Projector sizing for performance area
post #1 of 4
Any advice on a projector that would give a bright enough image, while using full house lights on a 16 foot by 9 foot screen. The screen material has not ben spec'd yet. This is for a large conference center and the screens will be on both sides of a 35 foot stage.
I came in late on this project, and need some suggestions (the lower the cost the better). 720p or 1080p projectors are needed.
Thanks in advance.
post #2 of 4
4000 calibrated lumens minimum on a 1.3 gain screen.
post #3 of 4
Cam did you ever finish your space, last time you posted you had a few loose ends, a fiancé, and a new job?
Anyway I bet one of these would get the job done and if you contact them give you some advice one your project.
http://www.digitalprojection.com/Bro...0/Default.aspx
be prepared for sticker shock.
post #4 of 4
Thanks for the replies guys.
DC, Don't have the fiancee any more, but the theater is done, except for front row seating and wiring the butt kickers LOL.
