Originally Posted by
proud2bpinoy
I updated the firmware on my TV yesterday and the 24Hz Handshake problem on my PS3 disappeared. But the problem on my WDTV @ 1080p 24Hz is still there. I am using cheap HDMI 1.3 cable on both setup.
Again, I'm no expert, but from all of the reading I've seen on this problem (which has been seen on DLP, LCD, Plasmas, PS3s, BD players, etc) it's virtually always been the cable.
In theory the HDMI 1.3 spec specifies the 10.2Gbps required for 1.4. But when buying a cable make sure it's a high speed cable. There are "low cost" and "cheap" cables. Low cost just cost very little but work great. "Cheap" cables are likely not up to spec and cause issues (like this).
Go to monoprice.com and buy some High Speed HDMI cables (24AWG to be safe). This place has quality cables for the best price you're likely to find anywhere (I got 3 x 6ft 24AWG HDMI High Speed cables for $18 shipped.... that's $6/ea.... not bad).
Mike W.
