AVS › AVS Forum › Video Components › Home Theater Computers › HTPC - Mac Chat › Apple TV 2 HDMI -> DVI?
post #1 of 5
Trying to hook up my Apple TV 2 to a Panasonic 42" plasma with DVI input.
TV has a DVI input and I connect it to my Sony A/V receiver via a DVI-HDMI cable. DirecTV (HD DVR), BluRay (Sony), XBOX all work flawlessly.
Got the ATV2 and its working about 5% of the time. I turn it on, it has redraw issues (black squares on the screen) and no sound. When it doesn't have the redraw problems it shows a line of static along the left edge of the screen. Turning off then on until it shows a clean display is getting rather annoying.
I've tried with my kids 20" el cheapo Best Buy 720p TV (Insignia) and the ATV2 is perfect.
I've tried with several HDMI cables, same problem.
I've tried with different HDMI-DVI adapters (the old one I got when the TV was new about 5 years ago) as well as a new Rocket DVI-HDMI adapter - same problem.
Seems that Apple TV 2 doesn't like DVI
http://discussions.apple.com/thread....t=45&tstart=60
Any suggestions that won't cost me an arm, or a leg?
post #2 of 5
I've had the same problem, also with a Panasonic TV. My Apple TV2 won't output above 480P and when I expand to fullscreen, I get a few pixel wide column of static on the left edge of the screen.
post #3 of 5
I am wondering the same thing. I would like to convert the HDMI signal from the Apple TV Version 2 to component so I can send it into my matrix switch but I don't feel like buying and trying everything under the sun until something works. I have a verity of projection, LCD and plasma devices in the house that are feed from the switch.
Does anyone have any recommendation on hardware to handle the conversion?
Thx, Chris
post #4 of 5
Google HD Fury 2
post #5 of 5
Thanks for the reply. I purchased a HDFury3 and it has been working perfectly. At first I didnt want to spend over $200 on a converter but I am glad I did.
Chris
  Back to Forum: HTPC - Mac Chat
