Originally Posted by
Brad Horstkotte
Sounds great to me, but obviously I'm a little biased. If you're looking for people to suggest restraint, this probably isn't the best place to ask.
Probably going to pull the trigger.....
I'm also probably going with the Onkyo NR 1007 via a good B Stock Website....
So...what is left but surrounds:
My two choices:
1) Emotiva ERD-1
4 ohm Driver.
One 5.25" Woofer, two 25mm tweeters
Sensitivity:
89db (2.83volts @ 1 Meter)
Recommended amplifier power:
50-200 Watts RMS
Frequency response: 80hz-20Khz +/-2db
Weight:
29.5 lbs pair (boxed) - 11 lbs. each (unboxed)
Selectable switches:
1. Left/Right Bipole
2. Left Dipole
3. Right Dipole
4. Left/Right Inverted Dipole
Unboxed (each): 13" wide x 9.5" high x 4.25" deep
2) Axiom QS8
Enclosure: Acoustic Suspension
Max Amp Power: 400 Watts
Min Amp Power: 10 Watts
Freq Resp +/-3dB (Hz): 95 - 20 kHz
Freq Resp +3dB- 9dB (Hz): 65 - 20 kHz
Impedance (Ohms): 8 Ohms
SPL in Room1w/1m(dB): 98 dB
SPL Anechoic 1w/1m(dB): 94 dB
X-Over 2.5 kHz
Tweeter: Dual 1"
Woofer: Dual 5.25"
Sub Woofer: -
Dimens. H W D (inches): 8.25" x 11" x 6"
Dimens. H W D (mm): 210 x 280 x 152
Weight (lbs) each 13.5 lbs
Weight (kg) each 6.123 kg
So guys...which one?
I'll be powering my L/C/R, Heights and Zone 2 with an Emotiva UPA-7, and my Onkyo NR1007 the Surrounds....or mix it up however I would need to.
I'm worried most about...difference with the 4 ohms/8ohms? I'm leaning towards the more sensitive Axioms....or just waiting and getting something later........
