Originally Posted by Quatre
this thing says its "the only media player in the world that can play 3d bluray isos"
http://www.himedia-tech.cn/en/product_show.php?id=27
I'ma lso wodnering about teh oppo 3d bluray player that supposedly can play 3d bd isos from an attached external hdd.
The Oppo can play bluray iso from a locally connected USB or SATA hard drive. The Oppo BD-95 has direct analog audio outputs for surround sound, while both the BD-93 and BD-95 have digital audio outputs.
The Oppo players cannot play bluray 3D correctly from a Lan based streaming source.
The Himedia 900 players can play bluray 3D both from a local hard drive and also from over a lan from a server. It is the Lan based playback that makes them unique. Himedia is one of many that use the Realtek 1186 system chip. See this thread for info.
http://www.avsforum.com/avs-vb/showthread.php?t=1384106
The Oppo is older and more proven, yet lacks some newer features of other newer media players that the Oppo might never have. The Oppo has direct USA support, while the support for the other players is still "ramping up."
Both the 93 and 95 have analog audio outputs for 7.1 connections. The 95 uses higher quality components in the audio section. Comparing the 95 and 93 is more like comparing the older 83 SE with the 83. The 95 also has internal wifi and the 93 does not. The 95 is considered an "audiophile" version of the 93 as the 95 is built with superior DAC's and heftier power supply.
