AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Samsung C6xxx Firmware question
post #1 of 4
Considering there isn't to much difference between the 300, 400 and 500 other then the internet@TV, apps and a few technical features. Would the firmware from the 400/500 install successfully on the 300?
Basically what I'm asking is if these sets are that similar why doesn't the 300 come with internet@tv and apps? Is it just a Samsung price point thing?
Would you be able to gain features if a 300 was flashed with 400/500 firmware?
post #2 of 4
anyone? not even a "no, not possible?"
post #3 of 4
Firmware is tv specific. You should use only the one offered for your tv. Installing other firmware can ruin your tv.
post #4 of 4
check Samsung website for available firmware updates for your model. It will only install the firmware for you model.
