Originally Posted by coderguy
It's called a loss in shadow detail and is muddy blacks, where the detail in dark scenes looks blended together and muddy. It is also referred to as black crush sometimes. You need to raise the brightness settings and adjust the gamma on the projector, that should help with your black crush.
The brightness control is actually the BLACK LEVEL, the contrast control is the white level. The gamma also affects it between those points though.
This projector's strength is not black levels, you would have to buy a Mits hc4000 for that or an Acer 9500bd, or an Epson 8700ub, or for the nirvana of black levels a JVC projector. Still even with the JVC, the black levels are still pretty far away from PLASMA-like black levels. A projector can only make the black so black.
A gray screen actually cannot help in a bat-cave other than reducing BRIGHTNESS, it only helps in non-bat-caves, but there are also downsides to gray screens sometimes, just depends. I probably recommend an ND filter instead of a gray screen to reduce brightness if the image is too bright unless you are in a room with white walls or ambient light, then a gray screen is the way to go. The problem with using a gray screen to get better blacks in a darkened room, is after the lamp on the projector ages, you'll be stuck with a darker image. An ND filter can be removed after the lamp ages, but you can't remove the screen (well I suppose you could, but you get my point).
thanks coderguy..I'll mess around with the brightness/gamma settings to try and get the image watchable..I don't mind "grays" instead of blacks as long as I can see the details in there
