AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Viewsonic Pro8200 -- it exists.
Viewsonic Pro8200 -- it exists. - Page 29
post #841 of 1020
Originally Posted by 73shark View Post
Return Material Authorization
...rarely.
Usually, return merchandise authorization.
post #842 of 1020
Originally Posted by stkguy View Post
That is one thing that I over looked when I purchased this projector and I wish that I would have taken the time to read more thoroughly through some of these threads. I can can only compare it to a few others, but this projector has an abnormally high throw. In my set-up I would have to set the thing practically on the ground if you want to run it without having to prop up the back..
We regularly mention the high offset of the projector. The HD20 has a relatively low offset for a dlp projector. The pro8200 has about the same offset as the hc4000. It does make installation difficult in a basement.
I built my own projector mount which gets the projector within an inch of the ceiling. It's just two pieces of 1/2" mdf. One piece is mounted directly to the ceiling with allthread fixed to it at the corners. The other piece is mounted to the projector. I'll make a drawing if you're interested. It takes minimal diy skills.
If you're using a solid screen you can just mount the top of the screen away from the wall, at the same angle you point the projector up, to raise the image on the wall without having to use digital keystone. That might take more carpentry skills, though not a lot.
post #843 of 1020
I may have to use your idea for a more flush mount. Mine is a 12" mount which would make life even worse. Even with a flush mount I couldn't get the lens center within an inch of the ceiling but at least we're getting closer. The idea of tilting the top is another I hadn't yet thought of. I might even be able to move it a few inches higher on the wall with it being angled downward. The only problem is I play a lot of video games and I'm trying to reduce eye strain and neck strain as well. I'm worried that moving it up the wall could lend to more neck strain. That doesn't mean I still can't tilt it downward to make up for the keystone issue. Good ideas.
If you can describe your mount a little more I can probably figure it out. Looks like there aren't any vents on that side so mounting a sheet of MDF flush to the PJ should be alright. I assume you made it larger than the PJ so you could get to the corners and then just then drill holes at the corners for allthread and then use nuts & bolts to attach the two pieces? As of right now my theater is an unfinished area of the basement so I was even considering building a bracket between floor joists to be able to mount it more flush with the ceiling. While this would help things out now I plan to finish it sooner than later so this would only be a temporary fix.
post #844 of 1020
I'll be making my own mount as well. Anyone know the screw type on the bottom of this unit? I'm guessing M3 based on what I can find on the net.
post #845 of 1020
I mounted my projector on my second floor - and mounted a cross brace in the attic between the joists so I get a more flush mount. If you've got the ability to do so in your basement, I wouldn't be afraid of doing that. I have about a 2" diamter hole in the sheetrock that the mount comes down through. If you ever move, you could always just leave a part of the mount in the ceiling above the sheetrock.
post #846 of 1020
I believe its an M4 actually. I just cant remember off the top off my head. Either way I was able to find the answer buried somewhere here in one of these threads I think.
post #847 of 1020
I'll just buy both. Thanks.
post #848 of 1020
Mine arrived today and I had the same question.. a quick search resulted in an online manual that stated that the Pro8200 uses 3 M4x8 screws to mount.
post #849 of 1020
Please post a photo or drawing. My PRO8200 will arrive on Friday so I need some ideas. Thanks!
post #850 of 1020
Check out this thread, specifically post #16 and #18:
http://www.avsforum.com/t/1401091/best-first-projector-for-under-900-and-120-screen#post_21813200
By using allthread or bolts you can adjust the projector.
post #851 of 1020
post #852 of 1020
Ok, here's a picture of my mount. In this case I have a vaulted ceiling. Make sure you elongate the projector mount holes for the allthread so that it will allow the lower mount to be angled. Mounting the projector to the lower board, I made the holes aligned with the projector oversized and then used fender washers. I did that for two reasons. I didn't have a template and was basically guessing where the holes should be to keep the projector square to the mounting board and it allows small adjustments to the projector. Snug down the projector mounting bolts, but don't get them too tight and when the projector is hung you can make very small adjustments to the alignment.
post #853 of 1020
That's kind of what I ended up with but my bolts aren't quite as long. Once I have time to coat it I will get some pics to post up.
post #854 of 1020
Well, I've had my PJ running now for a couple days. Not totally installed and setup the way I plan it, but running. I have a question I'm sure is in the thread somewhere but can't locate. How do you adjust overscan? I'm getting overscan, and my PJ is set to "3", what ever that means. I can't seem to adjust it. I assume I want "0".
Here's a mini review / warning to new Pro8200 users, for what it's worth. This thing sucks out of the box. When I first started watching it, blacks were totally crushed up, blues were blown way out (Avatar was painful to watch), all colour saturation was blooming, a total mess. Next, trying to navigate and make the necessary adjustments proved fruitless. Thanks to this thread I found the part about must setting your player to RGB mode. How silly is that, I don't get it. But yes, that fixed the blacks. I would have tried this eventually, but this thread saved me a ton of time. As for the blues and saturation, that took some twiddling, and I've only worked on it by eye, but it's now very very good. I'm surprised it came in so nicely. Coderguy is right, the colours on this are very accurate. As for the black performance, hey, I wanted the HC4000 but cheaped out. I'm not dissatisfied. Yes, black is a dark grey at best, but the gradation is there and the brain gets fooled by dark grey really easily. Compared to my plasma which has really nice blacks, it's far from good. But the truth is, you don't know it while watching. Space scenes might look weird, haven't tried any yet. But dark action scenes have the necessary gradation to keep me satisfied.
And it's certainly smaller and quiter than my 100lbs CRT noise box I had 12 or 13 years ago eek.gif
post #855 of 1020
I will try RGB mode for sure as I was unable to get decent colors out of mine. I also had to crank my brightness ALL the way down to get the blacks to not be bright gray. I haven't used it enough to make sure the rest didn't suffer and know I will turn it back up after that brand new bulb settles but for now I know it's about half of what the default was or less.
Can you post the out-of-the-box settings you came up with? Since the settings posted are after the bulb has broken in plus I have a friend who is going to come over to calibrate it for me with his calibration tool I just need something that is close enough to get me by to put 100hrs on it before I calibrate it. Thanks!
post #856 of 1020
Hey Jeremy,
I still will likely change these as the bulb burns and I have more viewing time. At the office, so by memory it was something like this:
Standard
Brightness = 45
Contrast = 50 or 55
Colour = Mid
Saturation = 47 (I found this setting fairly sensitive, lower 40s were washed out, over 50 it bloomed)
Tint = 50
Red = 50, 60 (sat/gain)
Green = 50, 55
Blue = 45, 35
Megenta = 50, 55
Cyan = 50, 50
Yellow = 55, 50
Eco ON
Sharpness = 5
Gamma 1
Can't remember what else to adjust.
Definitely set your source to RGB if it can be. But grey blacks wasn't the problem for me when I had it on auto or YpBpR (or what ever it is). It was quite black, just crushed. LIke the brightness setting was at 0 or something. So maybe your grey blacks aren't related.
Do you happen to know how to adjust overscan?
post #857 of 1020
http://www.avsforum.com/t/1390576/viewsonic-pro8200-calibrations
Here is a thread on pro8200 calibrations.
I had pretty good luck with the settings in post #6
post #858 of 1020
Hey Jeremy,
Standard
Brightness = 45
Contrast = 50 or 55
Colour = Mid
Tint = 50
Green = 50, 55
Blue = 45, 35
Megenta = 50, 55
Cyan = 50, 50
Yellow = 55, 50
Eco ON
Sharpness = 5
Gamma 1
I'm not in a hurry as I won't be on the projector until later today at the earliest. If you can post the exact settings (unless you're pretty sure those are right) when you get a chance I would appreciate it.
Thanks for the link. I already found that thread when I was searching but hadn't seen post #6 since I was looking for a list of settings like tuxedocivic post above. I tried the BSE settings in post #2 since it was said that it was better for newer lamps but I wasn't aware that post #6 was for brand new lamps so I'll give that a look too. Where does he say that's for a brand new lamp as I'm not seeing it? Thanks!
post #859 of 1020
Sure, I can post the exact one, but I'm headed out of town around noon and wont use the PJ until tomorrow. I'm pretty sure those are close. They'll get you close to where I was (which is only an eyeball test).
Thanks for the link bse53. I'll have to give those a try too. Probably better than my eye calibration Jeremy...
post #860 of 1020
Yeah, I may try those first since he's got exact settings for sure. Maybe after you try his you can compare the two and then post back your findings as far as if you liked anything you did differently than what he did.
post #861 of 1020
Sure. Judging by the info in that post, he has a more blacked out room than me, so if mine are better to me, it would likely be related to that. So depends on your room too.
post #862 of 1020
Makes sense.
post #863 of 1020
Alright, so I'm in the settings and entering all of the settings from that post #6 but there are a few issues. I can't seem to find this RGB setting anywhere. Plus your settings only have two entries per color but there are three? In addition, I noticed some unusual behavior while adjusting settings... specifically the red, blue, green, magenta, cyan and yellow. Where he had them at 240 the default was 0 so I would crank it up which took which took a while but the picture wouldn't change and then all of a sudden it would pop to a weird color and then it would start to come back to a normal color as you approached the 240. Also, I'm finding the my brightness needs to be 25 or less before my blacks begin to approach anything that's not gray.
post #864 of 1020
Take your time, bro, look in the comments on post 6 in the calibration thread linked a few posts above, it has 3 entries per color. Also, make sure you do everything in comments and anything else in that post.
For RGB, look in pro8200 menu, under "settings", then "signal type", change it from "auto" to RGB.
For example ,in comments , the red he has 240/75/64, those are 3 settings for that color. yellow he has towards bottom of his post.
Also, check your other equipment menu's too, and tell us your equipment, and if you are using A/V reciever and hdmi cable that came with pro8200. All this stuff helps, if you want the guys to help you.
post #865 of 1020
Yeah, I get that there are three settings per color and I have set all of those. Like I said as I was adjusting some of them there was no change to the picture then it would suddenly have a drastic change then slowly adjust back to somewhat normal. This is all while I was holding down the key to adjust from 0 to 240. Then to the next setting on the same color and so on. My comment about your settings was that you only had TWO settings for each one instead of THREE which I don't understand.
post #866 of 1020
What are you saying, it's very confusing. Your first sentence say's I get there are three settings per color, than your last line says the opposite.
As for shift in color as it's changing, I don't think that is problem. Maybe edit your posts and re-read them, mistakes happen. They do to me. smile.gif
post #867 of 1020
No, I know what I'm saying but I think the confusion lies with where I said 'your settings' I was actually talking to tuxedocivic who posted the following settings below:
Hey Jeremy,
Standard
Brightness = 45
Contrast = 50 or 55
Colour = Mid
Tint = 50
Green = 50, 55
Blue = 45, 35
Megenta = 50, 55
Cyan = 50, 50
Yellow = 55, 50
Eco ON
Sharpness = 5
Gamma 1
The ones I highlighted in bold should have THREE settings instead of the TWO he has listed. This is what I was talking about both times. I get there are three for each of those colors and in fact that's why I was asking him several posts ago why he had only listed two for those highlighted that should be three. I was able to find the RGB setting and when I toggle it back and forth there is a pause while the unit changes settings but I don't really see a difference in the picture quality or colors between the two. It could just be that in auto mode it selects the correct pallet for that particular input device but that's just guessing since I don't know for sure.
Speaking of input device.. I'm running an Xbox 360 that I use for streaming movies from my PCs and TV capturing/streaming via Windows Media Center and gaming. Once device handles all of our entertainment needs. The A/V receiver is an Onkyo.. forget the model but it's nothing fancy.
post #868 of 1020
LOL, BSE53 listed probably the best settings, the other guy was going by memory and was just giving stuff from what he remembered. 360 xbox for me too, Battlefield 3 in jets is pretty cool and forza motersport. So you know to check the A/V reciever settings too. The picture should look awesome. If not, maybe just for testing purposes, plug your 360 straight into the back of the pro8200 and see how it looks using the supplied hdmi cable from pro8200.
It was kind of confusing having the back and forth with you, "who's on first, type thing". smile.gif
post #869 of 1020
Yeah, BSE53's settings is what I have in my projector now minus the brightness. I finally settled on about 20 for brightness and even a few clicks below looks pretty good too. I think it's due to my dark room, bright shiny screen and the fact that my projector now has a whopping 8hrs on it. lol
As for my receiver... I don't think it had video settings. I will have to check into that.
post #870 of 1020
how big a screen, I guess you can just test going into the back of the pro8200 from 360, just to figure out if there is a difference. Also, test moving the PJ further from screen and changing zoom, should tone it down a little too. Yeah 8 hours is SUPER Bright, it will only get better and better and then even better. smile.gif
