Originally Posted by jasoraso
ThomasAV, you are correct. For a 100" screen, with maximum zoom, the greatest distance for the lens of the Viewsonic Pro8200 from the screen is 15'7". The offset will be 16.8". If you play around with the various variables in the ProjectorCentral calculator, you will notice that for a given screen size, the offset is constant, regardless of the amount of zoom. I can confirm that is correct. (offset doesn't change w/ zoom).
One other item to note - for a given screen size (100") - for the Viewsonic, the available mounting range is 10'2" to 15'7". Note that the offset stays the same. Also note that for the 100" screen size, the brightness of the image will vary between 34fl at 10' and 25fl at the 15' mounting point.
For comparison, the Epson 8350 is much more flexilble in its mounting options, but that isn't necessarily a good thing. For a 100" screen with the Epson 8350, the zoom allows mounting anywhere between 9'9" and 20"9". Quite a range. However, the Fl of the image varies from 34Fl at 9'9", to 14fl at 20'9" is a very large change. In the case of the Epson, you probably would want to mount the projector based more on desired light output, rather than the easiest installation point.
Depending on your room and viewing conditions (lights, windows, wall color), your desired light output from the projector may dictate the mounting position more so than other factors.
One last consideration - I believe the ProjectorCentral Calculator is pretty accurate with regards to the math calculating throw distance, zoom range, and offset. However, the Fl calculations are taken straight from the manufacturing supplied information as well. You should factor in the fact the Fl output of a projector varies greatly over its life and depending on the calibration/mode (eco, full brightness v. theater selection).
CoderGuy, an owner of a Viewsonic Pro8200, and frequent poster, has a link in his signature to a calculator that has a little more real-life calculations for the Fl you can expect out of a projector.
So if all else is equal, ideally you want to mount your projector near the front of that mounting window, right? This way your ideal image calibration will use less brightness than if it were at the back which could lengthen the overall life of your lamp, correct? Again, all other things equal. Seems like a basic idea so I want to make sure it applies.
