AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Phono preamp or Receiver with Phono input?
post #1 of 5
So I am brand new to the home audio game and am looking to build up a system in the coming months. I am going to start with buying a turntable and a receiver.
So I was wondering if having a phono preamp stage would be preferable/more cost effective than having a receiver with a phono input.
I was looking at the Onkyo HT-RC180 with a phono input, and would also allow me to integrate my tv and ps3 once I get some decent speakers.
Also, just as a general question: is THX certification worth it or just something to trick me into paying more?
post #2 of 5
I guess the obvious comment is that adding a phono amp (which can be quite cheap,) gives you more receiver choices.
As for THX, well, they supposedly do require certain exacting standards. Whether that means you get better sound, I can't say. Arguable, some receivers would likely meet THX standards if submitted, but the manufacturer can't/won't justify the price of certification.
post #3 of 5
An old Adcom 565 pre amp is highly regarded. It's phono stage is very sought after.
post #4 of 5
Check out THIS SITE !!
post #5 of 5
Has anyone heard anything about the Onkyo HT-RC180? It seems to have most of the features I'm looking for and at a pretty decent price. I suppose the real question is whether or not I would be paying too much for the phono input or could I get a receiver with similar specs and a preamp for less (THX certified or not).
