AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official OPPO BDP-95 Anticipation Thread
post #1 of 1008
We have a new home: Official OPPO BDP-95 Owner's Thread
Spoiler
BDP-95 Coming February 2011
Register to be Notified By E-Mail When The BDP-95 is Released
High Fidelity Audio Performance:
  • SABRE32 Reference Audio DAC - The DAC (Digital-to-Analog Converter) is one of the most important components for digital audio playback. The SABRE32 Reference ES9018 from ESS Technology is the world’s best performing 32-bit audio DAC solution targeted for high-end consumer applications and professional studio equipment. With the ESS patented 32-bit Hyperstream™ DAC architecture and Time Domain Jitter Eliminator, the SABRE32 Reference DAC delivers an unprecedented DNR (Dynamic Range) of up to 135dB and THD+N (Total Harmonic Distortion plus Noise) of -120dB, the industry’s highest performance level that will satisfy even the most demanding audio enthusiast. The BDP-95 uses two ES9018 DAC chips - one for the 7.1-channel output, and another for the dedicated stereo output.
  • Toroidal Power Supply - Custom designed and built by Rotel, the toroidal power transformer offers superior inrush current and much lower exterior magnetic field over traditional laminated steel core transformers. The BDP-95's toroidal linear power supply provides a very clean and robust power source to the critical audio components.
  • Dedicated Stereo Output - The BDP-95 features a dedicated 2-channel analog output with specially optimized ES9018 DAC and output driving stages. Each output is driven by 4 DAC channels stacking together to achieve even greater audio performance.
  • XLR Balanced Stereo Output - The stereo output offers both XLR balanced and RCA single-ended connectors. The balanced output features a true differential signal path all the way from the DAC to the 3-pin XLR connector. By transmitting a pair of differential signals, the balanced output provides better common-mode noise rejection and improves signal quality.
  • 7.1-Channel Analog Output - Individual analog 7.1-channel surround outputs are ideal to connect to a 7.1-channel or 5.1-channel surround sound system. Powered by the ES9018 SABRE32 Reference DAC, the BDP-95 delivers an incredible and immersive multi-channel soundstage.
  • Digital Optical and Coaxial Outputs - For simple and easy connection to more traditional A/V receivers, the BDP-95 features both optical and coaxial outputs for digital audio.
  • Dolby® TrueHD - Dolby TrueHD delivers lossless studio master quality audio designed specifically for high definition entertainment. The BDP-95 supports bit-stream output of Dolby TrueHD via its HDMI 1.4a output. It can also internally decode Dolby TrueHD into LPCM and output via HDMI or the 7.1ch analog audio output terminals. (Dolby Digital and Dolby Digital Plus audio formats are also supported.).
  • DTS-HD Master Audio™ - DTS-HD Master Audio delivers an auditory experience that matches the lifelike images of high-definition video with up to 7.1 channels that are bit-for-bit identical to the studio master. The BDP-95 supports bit-stream output of DTS-HD Master Audio. It can also internally decode DTS-HD Master Audio and output via HDMI or the 7.1ch analog audio output terminals. (DTS-HD High Resolution Audio and DTS Digital Surround are also supported.)
Note - Although the BDP-95 shares the same playback platform as the BDP-93, it is designed from the ground up with a different chassis and many different components optimized for the analog audio performance. For this reason it is not possible to upgrade a BDP-93 to gain the BDP-95's enhanced audio performance by replacing parts.
Diversified Media Support:
  • Blu-ray Disc - The high definition Blu-ray Disc™ format provides pristine video and audio quality for your home entertainment.
  • Blu-ray 3D – Experience high definition in all new dimensions. The BDP-95 supports the new Blu-ray 3D specifications (3D television and glasses required).
  • Netflix Instant Streaming Ready - Instantly watch movies streamed to your TV via the internet when connected to the OPPO BDP-95. (Unlimited membership required. US only)
  • Blockbuster on Demand - The newest releases instantly from your couch! (Service available in the United States only)
  • BD-Live & BonusVIEW - The BDP-95 supports BD-Live™ (Profile 2.0) and contains all necessary hardware - audio/video decoder, Ethernet and wireless networking, and 1GB of internal storage - for BD-Live. It also supports BonusVIEW (Profile 1.1) enabling "picture-in-picture" and audio features for viewing director or actor commentary while the main movie is playing.
  • DVD-Audio - The BDP-95 plays DVD-Audio and supports both stereo and multi-channel high resolution audio programs. Users can select whether to play the DVD-Audio or the DVD-Video portion of the disc.
  • SACD - The BDP-95 plays Super Audio CD (SACD) and supports both stereo and multi-channel high resolution audio programs. Users can select whether to output the DSD (Direct Stream Digital) signal in its native format over HDMI or convert it into high resolution PCM.
  • Additional Disc & Media Formats - Additional disc and file formats, such as DVD, audio CD, HDCD, Kodak Picture CD, AVCHD, MP4, DivX, MKV, FLAC, WAV and other audio/video/picture files on recorded discs, USB or eSATA drives can be played back on the BDP-95.
Unparalleled Video Quality:
  • Qdeo by Marvell - The BDP-95 incorporates Marvell's Kyoto-G2 video processor with the second generation Qdeo™ technology. Qdeo video processing delivers a truly immersive viewing experience by rendering quiet natural video free of noise and artifacts for all types of content. For high-quality Blu-ray content, the BDP-95 faithfully reproduces the program just as the director intended; for DVD, the up-converted picture quality bridges the visual gap from your current DVD library to Blu-ray discs; for network streaming and user-encoded content at a variety of formats and quality, the BDP-95 offers enhancement options including video noise reduction, compression artifact reduction, intelligent color, contrast, detail and edge enhancements. More Info
  • DVD Up-Conversion - Per-pixel motion-adaptive de-interlacing and advanced scaling transforms the standard definition image on DVDs to near high definition video quality. Additional Qdeo video processing options help to deliver a clearer, smoother, and true-to-life picture free of noise and artifacts.
  • Full HD 1080p Output - The BDP-95 features user selectable video output resolutions, including 480i, 480p, 720p, 1080i, and up to 1080p 50 or 60Hz.
  • True 24p™ Video - Many Blu-ray Discs are recorded at 24 frames per second, the same frame rate as the original movie's theatrical release. The BDP-95 can faithfully redeliver the original frames using 1080p 24Hz output (compatible display required) for smoother motion and a flicker-free, film-like home theater experience.
  • Source Direct Mode - For users who wish to use an external video processor, high-end audio/video receiver or display, the BDP-95 offers a "Source Direct" mode. The original audio/video content on the discs is sent out with no additional processing or alteration.
  • Multiple Zoom Modes - The BDP-95 supports multiple levels of aspect ratio control and image zooming, including a vertical stretch mode for customers with a 2.35:1 CIH (Constant Image Height) display system. A unique subtitle shift feature allows the user to move the subtitle up and down, making it possible to see all subtitle text when using a 2.35:1 CIH display. (Blu-ray discs with BD-Java may prohibit zoom operation.)
  • Dual HDMI v1.4a Outputs - Two assignable HDMI v1.4a outputs are provided to capitalize on the optimum audio and video settings to all old, new, and future HDMI televisions and receivers. With the option of full audio and video output to 2 displays; or dedicate one HDMI for audio, the other for video, it promotes a high quality video and audio for both signal paths. The BDP-95 supports 3D and Deep Color modes on both HDMI output ports.
Ultimate Convenience:
  • Dual HDMI Outputs – The BDP-95 is equipped with two HDMI output ports and offers the most versatile installation options. You do not have to upgrade your A/V receiver to a 3D model in order to enjoy 3D. One HDMI output of the BDP-95 can be connected to a 3D TV and the other can be connected to a pre-3D HDMI v1.1-v1.3 A/V receiver. For projector users, you can connect one output to a projector for home theater use and the other to a TV for casual viewing. For a multi-room installation the BDP-95 can output audio and video to two 3D or 2D TVs simultaneously.
  • eSATA Port – The BDP-95 features an eSATA interface on its back panel. Customers can take advantage of this fast interface to play contents from external hard drives and enclosures which contain audio, video and photo files.
  • Wireless & Ethernet – Using the included wireless-N adapter or the built-in RJ45 Ethernet port, users will be able to interact with BD-Live content, watch instant streaming programs from provides such as Netflix, Blockbuster etc., playback contents stored on their home network, and keep the BDP-95 up-to-date with firmware release to ensure maximum Blu-ray compatibility.
  • Dual USB Ports - Two USB 2.0 high speed ports are provided, one on the front panel and one on the back. Users can enjoy high definition video, high resolution photos and music directly from their USB drives.
  • PAL/NTSC Conversion - The BDP-95 supports NTSC and PAL systems for both disc playback and video output. It can also convert content of one system for output in another. (Subject to DVD and BD region restrictions.)
  • Back-lit Remote Control - The BDP-95 comes with a fully back-lit remote control for ease of use in dark home theaters. With its ergonomic button layout and clear labeling, operating the Blu-ray Disc player is easier than ever.
  • World Power Supply - The BDP-95 features a world power supply that is compatible with AC power from all regions. Voltage range from 100V-120V and 200V-240V can be selected by flipping a switch on the back panel.
  • External IR - For integration into home theater control systems, the BDP-95 provides external IR IN port to use with an IR distribution system.
  • RS232 Control - For custom installation, the BDP-95 offers an RS232 control port with a rich control and communication protocol. Installers can easily program their favorite control systems to operate the BDP-95.
  • HDMI CEC - HDMI Consumer Electronics Control simplifies the home theater by allowing a single remote control to operate multiple devices.
post #2 of 1008
For my personal use later, such as product images, etc.
post #3 of 1008
This is the one.
post #4 of 1008
Sweet! I can't wait!
post #5 of 1008
The 93 does not have a FAN but the 95 does.
post #6 of 1008
So if I have till January 18th to return my prerelease 93 I wouldn't have much lag time or maybe even less for a prerelease or would that be frowned upon. I do desire better analog than the 93.
post #7 of 1008
Fan, or no fan I want this thing right in my AV rack.... freaking 16 lbs, not that means anything but it's 16 pounds
Djoel
post #8 of 1008
I am sure when Oppo added on the website that your question was discussed.
post #9 of 1008
Required. The player produces a lot more hear than the standard BDP-93 design. However, with the release of the player occurring in February, it is still possible (though slim) that OPPO may find that active cooling is not necessary.
post #10 of 1008
I don't see Oppo Digital in AVScience brand list. Did I miss it? Just placed a pre-order for the 95 @ musicdirect.
post #11 of 1008
So if I have till January 18th to return my prerelease 93...
You have until January 20th. OPPO is using the first ship date of the BDP-93, which will be December 20th.
Frowned upon, yes. Allowed, yes.
post #12 of 1008
So hardware is not final. Why more cooling?
post #13 of 1008
So, reading the specs, what do we think the conventional wisdom will be on this player: if one needs analog perofrmance go with the 95, otherwise the 93 will suffice? Or will the performance of the 95 be distinguished even as a digital transport? I realize this requires a bit of speculation, but just curious what people think.
post #14 of 1008
You know I did the same thing last month, now I'm beginning to think we'll get it quicker directly via Oppo?
DJoel
post #15 of 1008
Much larger and substantial analog audio board and toroidal transformer. The player is substantially more complex than the BDP-93 and will have much more heat inside of the player.
post #16 of 1008
Correct. Potentially the torodial power supply and re-engineered internals will make the overall product better, but from a performance to cost relationship, the BDP-93 makes more sense as a transport.
post #17 of 1008
Well I am glad that it is allowed.
post #18 of 1008
DJoel
haha, great... you might be right. I feel better though knowing my order's in... ^)^
post #19 of 1008
Will the 95 improve upon the video of the 93 at all or is it the exact same?
post #20 of 1008
Video will be the same.
--Bob
post #21 of 1008
You know, I've been wishing for this unit for so long that I think I began to construct the fantasy 95 in my mind.
I hope the toroidal transformer implies discrete amplification on all output channels.
Now into pure fantasy: I wish Oppo would give more love to MCH output (say an extra ess32 to make all 7.1 channels 2xstacked)
And for an audiophile unit, it would have been awesome to see the frequency response dip a few Hz below 20.
But then I woke up, and it was Christmas morning - and there was still the most awesome looking (stats-wise) universal player for the money under the tree. Truth be told, this unit still looks to exceed my expectations. Thank you once again Oppo.
post #22 of 1008
It's like you have read my mind. Feature for feature, the 95 is exactly what I was hoping for. I'm very excited about the XLR outs.
post #23 of 1008
Looking forward to this. Been looking for a high end audio Blu-Ray player. Had it down to the Denon 4010, upcoming Denon 2012 and the Oppo 95. Likely 4010 will be out since it is older technology. But will have to read reviews on the Oppo and Denon before its a done decision.
~Bob
post #24 of 1008
wow, very cool looking player. Let's see if I finally replace my Denon DVD-3930CI (for playing RedBook CD's)
post #25 of 1008
wish we had some idea on BDP-95 retail price?
post #26 of 1008
just ordered Marantz AV7005 surround processor, it has 7.1 balanced OUT's (XLR), but no 2ch balanced INP's (XLR). I'm wondering if I could just connect BDP-95 2ch balanced OUT's directly to my Parasound Halo A51 amp's 2ch balanced INP's (XLR)? Or just connect it in conventional manner: BDP-95 2ch OUT's (RCA) -> AV7005 2ch INP's (RCA), etc.,...?
post #27 of 1008
See this post, still speculative.
post #28 of 1008
interesting, thanks! Sounds like a good deal
post #29 of 1008
GREAT !!
Finally, THE MACHINE !!
Now, only 2 things still concerned me:
1) A nice Region-Free module kit, as the one I have for the 83 ...
2) The "moves" of Jason for the 95 NuForce Edition ......
Thanks OPPO !!
Finally, Great decision !!
post #30 of 1008
Region-free mod is also what I'm waiting for.
And I have to decide whether to go with 93 or 95. Getting the 95 could mean I could sell my Pio BDP-09.
This thread is locked
