Originally Posted by
kitchen_space
Mid-Atlantic does not sell "fractional" rack blanking panels; they are all in multiplies of "U."
Huh? When did I suggest that M-A sells fractional blanking panels? There are or will be 2 different rack mount possibilities for the 95:
Option 1) Purchase ears from OPPO. If your guess that the 95 is exactly 2U with the feet removed, you remove the feet, attach the ears, and mount the 95 in 2 rack spaces. In this case, I would recommend installing a blank or vented 1U panel above it to give the 95 room to breathe. Total spaces used up in the rack = 3U.
Option 2) Purchase a Middle Atlantic custom rack shelf for the 95 when they show up in M-A's database. As is normal with M-A custom shelves, you would not remove the feet and the custom faceplate will use 3 rack spaces. Total spaces used up in the rack = 3U.
Nothing in my previous post suggested anything about fractional blanking panels.
