AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › How i can resolve this...
post #1 of 3
How i can clean this dust inside my 42" lcd panel? also i can see a ccfl lamp ghosting effect... i am sure that my tv have a lot of dust between the lcd and the ccfl lamp assembly. anyone have an idea how i can clean this ?
thanks
post #2 of 3
Will, are you sure that's dust, and not the sparkles effect caused by a bad hdmi cable?
Tom
post #3 of 3
no, its the sparkle effect from the ps3 background... look at the bottom, its not a dark spot, its like dust.
