Originally Posted by pbmpharmacist
According to a post by Gene their forum, the Audioholics Ultimate Subwoofer Shootout "Primer" will be online tomorrow.
The subs being tested are:
HSU VTF-15H
Rythmik FV15HP
Funkywaves FW12.X SA1000
SVS PB12-Plus
I'm very much looking forward to the results! Just thought I'd post this here so that everyone was aware of it.
good grief!!! how are ANY of those subwoofers listed consider "ultimate" in ANY way??? Give me a break. There are so many other subs available that would destroy those listed and make them cry in their soup. Here's a more likely list of "ultimate" subwoofers
CS 18.2
eD A7-450 & up
Seaton subs
Epik subs
etc....seriously...what a joke. They should call this the ultimate basic subwoofer shootout. I'm not saying the subs listed are not good, but...their price points are all higher than they should be, their performance is definitely much less than can be had for the same money from other competitors.
Just as an example, compare the Rythmic 15" sub listed to the Elemental Designs A5-350. Similar specs, but the eD is $400.00 cheaper and that INCLUDES shipping. Similar specs, so obviously a much better deal
eD A5-350 $800.00 including shipping
Driver Size 15"
Driver Quantity 1
Driver Excursion 23mm
Total Driver Linear Displacement 3331.04cm³
Room Tuning 20Hz
Frequency Response (+/-3dB) 18-100Hz
Amplifier RMS Power 500W
Cabinet Type Vented
Shipping Weight 108 lbs
Internal Size 4.70ft³
External Size 6.37ft³
Width 19.00"
Height 25.00"
Depth 24.75"
Vent Size 2 x 4"
Amplifier Voltage 115
Included Crossover Yes
Crossover Frequencies 35-180Hz
Phase Switch Yes
Line Level Input Yes
RCA Level Input Yes
Level Control
Rythmic FV15HP $1199.99 PLUS shipping
Driver DS1510 15" high excursion with custom sensing coil
Driver materials Black anodized aluminum with rubber surround
Cast aluminum basket
Copper flux modulation shorting rings
Amplifier 600 RMS class H patented servo controlled
Dimensions 18"(W) x 24" (H )x 24"(D) - (26" D with grille and heatsink)
Shipping Weight 120 lbs
Frequency Response 14 - 90 Hz (-2 dB @ 14 Hz)
Multi-tune 18hz (2 port) and 12hz (1 port)
Crossover slope Selectable 12 or 24 dB / octave (PEQ)
Crossover range (Low pass) 25 - 100 Hz
Rumble Filter (High pass ) 18 Hz 18 dB / octave for two port tuning
Phase adjustment 0 - 180 degrees continuously variable
Bass damping factor settings high (Q=0.5), med (Q=0.7), and low (Q=1.1)
Finishes Available in honey oak vinyl or black oak vinyl
Warranty 5 years warranty on driver and 2 years on electronics
30 day satisfaction guarantee
