Originally Posted by
penngray
I do not think the amp is "like" the 350Watt BASH amp. Does the BASH amp have > 1000Watt peak power abilities?
Hey there penn - I don't quite follow. The VTF-15H's amp isn't "like" a 350w BASH amp... it
is a 350w RMS BASH amp. As for whether the amp can truly supply >1000w peaks... we haven't seen any third-party tests validating the marketing/advertisement claims. The AH reviewer took a shot at explaining the amp's power potential, and if you read between the lines he seems to suggest that if it can really even hit 1400w, it must be for a nanosecond (paraphrasing, and IMHO). The amp even has a mark on it that states "430 Watts Max Power Consumption."
Its not an extremely expensive amp though even the LT/1300 (> 1000Watt amp) from eD would be < $400. Of course the 2000Watt amps from FunyWaves are $700, with 4000Watt peaks (so they say, I have not tested mine).
Yeah, that was kind of my point though - compared to those and other higher-end plate amps (LT/1300, FW custom amps, Dayton 1000w plate, etc.), one could call the 350w BASH amp in the VTF-15H "mediocre" relative to the spectrum of plate amps available. Mediocre means "middle, moderate, average" - is that a false description for a 350w BASH plate amp?
Hsu Research isn't a charity, we shouldn't begrudge them a profit margin, and the VTF-15H retails for $879. What's the realistic ceiling for the parts' cost (driver, amp, wood, finishing supplies, grille, port plugs, labor, et. al.) - $500, if that? There's no way the amp is anywhere near $400 of that... IMHO. I'd guess it's maybe around $100-150 of the overall cost, but that's just a guess.
