Code:
DISC INFO:
Disc Title: TOY_STORY_3_DISC_1
Disc Size: 47,692,786,476 bytes
Protection: AACS
BD-Java: Yes
BDInfo: 0.5.4
PLAYLIST REPORT:
Length: 1:43:03 (h:m:s)
Total Bitrate: 37.96 Mbps
VIDEO:
Codec Bitrate Description
MPEG-4 AVC Video 24431 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Codec Language Bitrate Description
DTS-HD Master Audio English 5506 kbps 7.1 / 48 kHz / 5506 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS-HD Master Audio English 3998 kbps 5.1-ES / 48 kHz / 3998 kbps / 24-bit (DTS Core: 5.1-ES / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio English 320 kbps 2.0 / 48 kHz / 320 kbps / Dolby Surround
Dolby Digital EX Audio French 640 kbps 5.1-EX / 48 kHz / 640 kbps
Dolby Digital EX Audio Spanish 640 kbps 5.1-EX / 48 kHz / 640 kbps
SUBTITLES:
Presentation Graphics English 38.857 kbps
Presentation Graphics English 47.074 kbps
Presentation Graphics French 39.571 kbps
Presentation Graphics Spanish 34.535 kbps
FILES:
Name Time In Length Size Total Bitrate
00296.M2TS 0:00:00.000 0:00:44.335 244,641,792 44,143
00344.M2TS 0:00:44.335 0:00:27.569 124,446,720 36,112
00297.M2TS 0:01:11.905 0:01:59.661 570,630,144 38,150
00345.M2TS 0:03:11.566 0:00:18.643 87,029,760 37,345
00298.M2TS 0:03:30.209 0:00:46.254 216,274,944 37,406
00346.M2TS 0:04:16.464 0:00:12.595 72,830,976 46,257
00299.M2TS 0:04:29.060 0:07:17.270 2,092,873,728 38,290
00347.M2TS 0:11:46.330 0:01:23.208 371,392,512 35,707
00301.M2TS 0:13:09.538 0:00:27.068 127,543,296 37,695
00348.M2TS 0:13:36.607 0:00:49.424 224,102,400 36,274
00302.M2TS 0:14:26.031 0:01:12.489 344,549,376 38,025
00349.M2TS 0:15:38.520 0:00:21.813 107,612,160 39,466
00303.M2TS 0:16:00.334 0:00:42.959 229,896,192 42,812
00326.M2TS 0:16:43.293 0:01:24.542 412,016,640 38,988
00304.M2TS 0:18:07.836 0:01:16.034 376,350,720 39,598
00478.M2TS 0:19:23.870 0:00:31.114 147,320,832 37,878
00305.M2TS 0:19:54.985 0:00:26.609 122,087,424 36,704
00328.M2TS 0:20:21.595 0:00:42.459 211,771,392 39,901
00306.M2TS 0:21:04.054 0:22:01.570 6,363,746,304 38,522
00353.M2TS 0:43:05.624 0:01:31.132 412,913,664 36,247
00307.M2TS 0:44:36.757 0:03:42.764 1,063,772,160 38,203
00354.M2TS 0:48:19.521 0:00:33.867 150,620,160 35,579
00308.M2TS 0:48:53.388 0:01:20.872 365,395,968 36,145
00355.M2TS 0:50:14.260 0:02:01.204 555,319,296 36,653
00309.M2TS 0:52:15.465 0:13:11.832 3,718,189,056 37,565
00356.M2TS 1:05:27.298 0:00:29.195 129,687,552 35,536
00310.M2TS 1:05:56.493 0:01:06.024 300,859,392 36,454
00370.M2TS 1:07:02.518 0:01:37.847 453,347,328 37,066
00311.M2TS 1:08:40.365 0:02:00.203 576,227,328 38,350
00371.M2TS 1:10:40.569 0:01:29.547 414,584,832 37,038
00312.M2TS 1:12:10.117 0:02:12.799 641,120,256 38,622
00372.M2TS 1:14:22.916 0:00:22.814 101,984,256 35,761
00313.M2TS 1:14:45.730 0:00:39.164 196,859,904 40,212
00373.M2TS 1:15:24.895 0:00:56.848 294,402,048 41,430
00314.M2TS 1:16:21.743 0:01:14.074 406,763,520 43,931
00374.M2TS 1:17:35.817 0:00:57.182 332,359,680 46,498
00315.M2TS 1:18:32.999 0:01:52.821 585,535,488 41,520
00375.M2TS 1:20:25.820 0:00:21.271 125,491,200 47,197
00316.M2TS 1:20:47.091 0:04:12.502 1,310,748,672 41,528
00376.M2TS 1:24:59.594 0:04:24.305 1,174,308,864 35,544
00317.M2TS 1:29:23.899 0:04:54.377 1,333,831,680 36,248
00377.M2TS 1:34:18.277 0:01:35.720 453,470,208 37,899
00318.M2TS 1:35:53.997 0:00:24.315 116,754,432 38,412
00378.M2TS 1:36:18.313 0:00:23.773 110,487,552 37,180
00319.M2TS 1:36:42.087 0:01:56.950 550,772,736 37,676
00477.M2TS 1:38:39.037 0:03:26.831 748,591,104 28,955
00484.M2TS 1:42:05.869 0:00:30.030 123,531,264 32,909
00343.M2TS 1:42:35.899 0:00:27.485 147,204,096 42,845
CHAPTERS:
Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time
1 0:00:00.000 0:04:53.543 24,976 kbps 38,454 kbps 00:03:24.203 32,296 kbps 00:04:30.812 31,937 kbps 00:04:30.853 130,193 bytes 640,999 bytes 00:04:00.198
2 0:04:53.543 0:01:26.711 25,677 kbps 33,606 kbps 00:06:05.656 31,245 kbps 00:06:01.611 30,672 kbps 00:05:07.015 133,869 bytes 524,082 bytes 00:04:55.086
3 0:06:20.254 0:05:17.150 24,310 kbps 34,960 kbps 00:09:08.839 32,114 kbps 00:09:13.344 31,760 kbps 00:09:09.131 126,741 bytes 641,062 bytes 00:11:34.860
4 0:11:37.405 0:03:39.761 23,306 kbps 35,516 kbps 00:11:40.658 31,794 kbps 00:11:39.698 29,657 kbps 00:11:38.364 121,506 bytes 606,923 bytes 00:13:13.542
5 0:15:17.166 0:03:17.030 26,603 kbps 34,969 kbps 00:18:32.486 32,105 kbps 00:16:23.565 31,686 kbps 00:16:22.648 138,697 bytes 640,874 bytes 00:16:05.631
6 0:18:34.196 0:00:49.674 26,206 kbps 37,833 kbps 00:18:35.781 28,919 kbps 00:18:34.196 27,653 kbps 00:18:49.044 136,628 bytes 600,161 bytes 00:18:36.198
7 0:19:23.870 0:06:53.246 23,853 kbps 35,696 kbps 00:19:29.042 32,395 kbps 00:19:24.830 31,663 kbps 00:24:51.990 124,361 bytes 640,948 bytes 00:19:29.334
8 0:26:17.116 0:02:42.287 23,290 kbps 34,850 kbps 00:27:03.163 32,115 kbps 00:26:59.159 30,696 kbps 00:26:54.154 121,424 bytes 640,755 bytes 00:26:19.035
9 0:28:59.404 0:02:48.418 24,291 kbps 35,415 kbps 00:30:26.866 31,891 kbps 00:30:13.811 30,108 kbps 00:30:12.810 126,641 bytes 641,037 bytes 00:31:15.581
10 0:31:47.822 0:01:34.511 24,036 kbps 33,653 kbps 00:33:19.038 31,781 kbps 00:32:52.803 31,566 kbps 00:32:52.220 125,313 bytes 640,332 bytes 00:32:08.759
11 0:33:22.333 0:02:27.730 22,514 kbps 34,558 kbps 00:34:37.116 31,656 kbps 00:35:29.710 29,189 kbps 00:35:26.624 117,376 bytes 634,632 bytes 00:35:20.910
12 0:35:50.064 0:01:40.058 23,486 kbps 32,783 kbps 00:35:51.649 28,860 kbps 00:36:30.187 27,727 kbps 00:36:26.475 122,447 bytes 588,357 bytes 00:35:51.065
13 0:37:30.122 0:02:41.202 30,175 kbps 34,894 kbps 00:38:36.021 32,005 kbps 00:39:06.969 31,620 kbps 00:38:20.047 157,321 bytes 640,459 bytes 00:39:12.683
14 0:40:11.325 0:01:01.311 31,142 kbps 33,879 kbps 00:40:40.229 31,775 kbps 00:40:36.934 31,568 kbps 00:40:31.178 162,362 bytes 525,101 bytes 00:40:41.939
15 0:41:12.636 0:02:24.853 28,701 kbps 34,122 kbps 00:42:35.219 31,754 kbps 00:42:35.094 31,461 kbps 00:42:17.868 149,635 bytes 640,166 bytes 00:42:42.893
16 0:43:37.489 0:01:11.780 23,797 kbps 35,523 kbps 00:44:00.762 31,696 kbps 00:43:56.758 29,102 kbps 00:43:56.091 124,067 bytes 513,498 bytes 00:44:23.202
17 0:44:49.269 0:03:30.251 24,673 kbps 34,005 kbps 00:47:21.171 31,608 kbps 00:46:43.717 31,002 kbps 00:45:49.579 128,635 bytes 517,858 bytes 00:45:23.053
18 0:48:19.521 0:04:08.539 23,236 kbps 35,879 kbps 00:51:45.852 31,883 kbps 00:50:31.486 31,548 kbps 00:50:27.399 121,144 bytes 639,544 bytes 00:50:36.408
19 0:52:28.061 0:01:23.833 24,498 kbps 33,122 kbps 00:52:45.829 31,320 kbps 00:52:39.489 30,371 kbps 00:52:37.821 127,721 bytes 618,772 bytes 00:53:38.381
20 0:53:51.895 0:03:20.074 24,526 kbps 38,052 kbps 00:55:36.916 32,072 kbps 00:56:36.559 31,113 kbps 00:53:54.314 127,866 bytes 640,511 bytes 00:55:36.666
21 0:57:11.969 0:01:08.735 23,877 kbps 34,803 kbps 00:57:11.969 28,917 kbps 00:57:27.610 27,892 kbps 00:57:23.648 124,484 bytes 639,892 bytes 00:58:14.115
22 0:58:20.705 0:02:49.294 24,658 kbps 33,915 kbps 01:00:15.027 31,632 kbps 01:00:39.719 31,409 kbps 01:00:35.131 128,557 bytes 634,230 bytes 01:00:25.121
23 1:01:09.999 0:00:56.639 25,353 kbps 37,753 kbps 01:01:13.628 30,402 kbps 01:01:18.341 29,403 kbps 01:01:18.299 132,180 bytes 640,855 bytes 01:01:16.005
24 1:02:06.639 0:00:50.383 25,060 kbps 33,784 kbps 01:02:45.094 31,400 kbps 01:02:13.646 28,640 kbps 01:02:30.287 130,649 bytes 450,688 bytes 01:02:29.787
25 1:02:57.022 0:03:38.009 22,743 kbps 33,565 kbps 01:04:04.590 31,711 kbps 01:03:59.794 31,425 kbps 01:04:01.337 118,573 bytes 640,752 bytes 01:03:06.782
26 1:06:35.032 0:04:46.703 24,215 kbps 33,391 kbps 01:09:26.620 31,376 kbps 01:09:36.839 30,200 kbps 01:10:06.285 126,248 bytes 638,329 bytes 01:09:24.076
27 1:11:21.735 0:04:35.525 24,785 kbps 34,971 kbps 01:12:30.137 32,058 kbps 01:13:01.585 31,269 kbps 01:13:55.722 129,219 bytes 640,991 bytes 01:13:48.715
28 1:15:57.260 0:01:38.556 28,833 kbps 34,283 kbps 01:16:47.060 31,802 kbps 01:16:43.056 31,562 kbps 01:16:38.176 150,320 bytes 466,100 bytes 01:16:14.361
29 1:17:35.817 0:02:07.377 28,689 kbps 34,519 kbps 01:18:32.457 31,859 kbps 01:18:23.865 31,628 kbps 01:18:23.573 149,571 bytes 496,701 bytes 01:18:09.601
30 1:19:43.194 0:03:18.740 29,397 kbps 35,314 kbps 01:20:33.911 32,003 kbps 01:20:29.907 31,624 kbps 01:20:24.902 153,263 bytes 634,787 bytes 01:22:54.719
31 1:23:01.934 0:01:57.659 23,256 kbps 35,108 kbps 01:24:28.396 31,679 kbps 01:24:22.849 29,714 kbps 01:24:19.762 121,246 bytes 639,977 bytes 01:23:27.543
32 1:24:59.594 0:03:15.987 22,031 kbps 35,232 kbps 01:25:20.656 32,365 kbps 01:25:16.652 28,734 kbps 01:25:01.095 114,857 bytes 640,788 bytes 01:25:10.104
33 1:28:15.581 0:06:02.695 24,129 kbps 37,856 kbps 01:32:22.369 32,121 kbps 01:33:28.435 31,697 kbps 01:33:28.435 125,797 bytes 641,019 bytes 01:28:56.789
34 1:34:18.277 0:08:45.107 20,011 kbps 33,637 kbps 01:42:42.322 31,784 kbps 01:42:37.734 30,720 kbps 01:42:36.191 104,335 bytes 594,993 bytes 01:37:28.133
Video: MPEG-4 AVC Video / 24431 kbps / 1080p / 23.976 fps / 16:9 / High Profile 4.1
Audio: English / DTS-HD Master Audio / 7.1 / 48 kHz / 5506 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Audio: English / DTS-HD Master Audio / 5.1-ES / 48 kHz / 3998 kbps / 24-bit (DTS Core: 5.1-ES / 48 kHz / 1509 kbps / 24-bit)
