Hi all, I've been searching around and I've found a little information about this problem. I was given this 52" JVC D-ILA tv because it has a slight yellow / green tint to the entire screen through the D-Sub and RCA/S-Vid ports.
I've ordered a DVI-HDMI cable to try higher resolutions but I have the feeling I'm going to be stuck with this greenish tint.
The screen is not too dim (sorry no pics atm) so I don't think I need to replace the bulb.
Does anyone know how to enter the Service Menu, maybe I'll be able to change color settings in there?
What kind of hardware would this problem be if it's not a software setting?
I'm having a hard time finding anything other than replacement lamps as this tv is now well over 3 years old. I'm starting to think this isn't even worth my time
I think there should be some type of class action lawsuit, but I guess that's just wishful thinking
. Anyway hope that helps.
