AVS › AVS Forum › Video Components › Home Theater Computers › Trouble Streaming Bluray from Unraid
post #1 of 8
Hello,
I have been pulling my hair out trying to figure out why I cannot stream bluray (in folder structure) to my HTPC from my unRaid server. Many users are doing it just fine and I am not convinced it is necessarily an unRaid problem...
I have searched and cannot find an answer, here is my setup:
Server:
Core2Duo E7500
Gigabyte EP43-UD3L (recently upgraded from an old MSI P6ngm)
4 drives: Hitachi 1tb, Seagate Barracuda 1tb, WD Caviar 1tb, Samsung 1tb
User shares enabled, file structure:
/share folder
/movie title
/movie folders
Split set to level 2
D-link DIR-655 router (server and HTPC are hard wired)
HTPC:
i3 540
Asus H55-M Pro
Samsung 500gb hdd
I am using TMT3 as my player and was using Media Browser in WMC7. I tried uninstalling Media Browser with no effect.
I am able to play discs flawlessly, and if I copy the movie locally it plays just fine.
Additional info:
I am on GigE at both ends. Ping tests show <1ms latency
I have tried enabling jumbo frames. (not sure if I need to change settings in the router...)
When I run ethtool eth0 in telnet it returns 1000mb/s @ full duplex
I can stream internet providers just fine: Hulu, Netflix, etc...
Any suggestions are welcome, I would rather not change to WHS!
post #2 of 8
Nevermind, I finally found it:
In the Realtek driver "Advanced" settings I changed the interrupt moderation to "disabled" and all works well so far.
I never thought to look farther into the driver setting on the HTPC...
post #3 of 8
Realtek onboard gigabit NICs tend to work less reliably in HTPCs for some reason. If you find your problem persists, you may want to consider getting an Intel PCI-E gigabit NIC. This is particularly true if you're using any extenders in conjunction with your Win 7 Media Center PC.
post #4 of 8
how did you happen to stumble upon that setting?
Does "Jumbo Frame" help a lot?
post #5 of 8
I stumbled on it by accident, actually and I'm not sure it is helping. I originally set it to 9000 but I have seen that copying to the server from the HTPC has issues. The transfer starts out around 30-40 MB/s then drop to around 1 MB/s. Hardly stellar performance! So I am still testing to see what works best. My guess is the limitations of the parity drive in the unraid box.
post #6 of 8
MTU router settings control Jumb Frames...any MTU setting >1500 is usually considered to be in the realm of a jumbo frame. I think avg MTU settings for jumbo frames are like MTU = 9000 (as the op has basically stated) or something along those lines. I believe that some game consoles do not support anything greater than a MTU of 1500 BTW too...
post #7 of 8
Changing Inerrupt Moderation on my HTPC didn't fix mine either.
post #8 of 8
Also check that "Flow Control" is disabled.
After doing some more testing, I discovered that the unraid network driver does not support 9000 MTU jumbo frames. The largest I can confirm is 7000. This is the largest packet size I can reliably ping from one to the other... YMMV!
