Originally Posted by mark haflich
................Ron. I note in your first post you refer to the JVC projectors having vertical polarization and the JVC glasses having vertical polarization. I thought that the reverse was true, the the JVC glasses and projectors had horizontal polarizers and ditto that the Xpands had vertical rather than the horizontal you stated..........
Good catch (faulty memory on my part) - I should have gone back and checked my own post on the big JVC thread from a few weeks ago. I've corrected it in Post #1. The JVC projectors and JVC shutter eyeglasses use horizontal polarization while most LCD flat panel 3DTVs and the Xpand X103 shutter eyeglasses use vertical polarization. So if a JVC 3D projector owner is using it with a screen that maintains any significant amount of polarization, they really should be using the JVC eyeglasses and not the Xpand X103s,
Would like to see some data for this brand.
