Finally have an Sony VPL-VWPro1, so thought of starting a Owners thread and add settings and questions.
The projector is very similar to VPL-HW15. But VWPro1 comes with an additional box (spare lamp). I will be posting more photos and etc.
Sony VPL-VWPRO1 General Features
Acceptable Computer Signals : fH: 19 to 72kHz, fV : 48 to 92Hz, Maximum resolution 1920x1080 fV 60Hz
Enhanced SXRD Panels : Minimizing the pixel gap from .25 µm to .20 µm, improves brightness and contrast while reducing screen door effect.
Three SXRD 1920 x 1080p : Micro-display panels support Full HD 1080p resolution for an impressive combination of vivid color, film-like image quality, and high-definition brilliance. Enjoy cinematic-quality images.
200W Ultra-High-Pressure Lamp : A 200W Ultra-High-Pressure Lamp delivers natural color with a brightness of 1300 ANSI lumens2.
BRAVIA Engine 2 : BRAVIA Engine 2 fully digital video processor uses a collection of unique Sony algorithms to significantly reduce noise, enhance overall image detail, and optimize contrast so every scene produces sharp, vibrant, life-like images.
Advanced Iris 3 : The Advanced Iris 3 function provides up to a 85,000:1 contrast ratio1 by optimizing both dark and bright scenes to produce deep black levels with stunning details.
24p True Cinema : 24p True Cinema technology provides a direct connection to 24p video sources so you can avoid conversions and enjoy films at their intended 24 fps (frames per second).
x.v.Color : x.v.Color technology3 takes HD color expression to new levels. When connected to x.v.Color capable video sources, such as select Sony camcorders, the VPL-VWPRO1 can display nearly twice as many (1.8x) viewable colors as the existing RGB color standard, resulting in more natural, life-like images.
Deep Color : By combining a 10-bit processor with 10-bit SXRD panels, the VPL-VWPRO1 can create and display 64 times the level of color expression of 8-bit projectors, resulting in smoother color gradations and helping to avoid a paint-by-numbers look.
ARC-F (All Range Crisp Focus) Lens : A specially developed ARC-F (All Range Crisp Focus) lens takes full advantage of the SXRD panels to deliver Full HD 1080p resolution with superior clarity and focus.
Noise reduction functions : The VPL-VWPRO1 features noise reduction functions that analyze scenes in real time to identify various types of noise and reduce unwanted artifacts, such as mosquito noise and block noise, without compromising the video signal.
Panel Alignment function : A Panel Alignment function enables pixel alignment to within 1/10th of a pixel5, making it possible to shift the entire picture to adjust for color gaps and produce a brighter, clearer, and more detailed picture.
1.6x Zoom Lens : A 1.6x zoom lens provides a short focus distance and takes full advantage of Sony® SXRDTM technology to provide superior resolution and focus.
Adjustable Lens Shift : Adjustable Lens Shift provides vertical and horizontal adjustments of the picture position expanding the projector's placement and installation options without distorting image quality.
Ultra Low Fan Noise 22dB : Exclusive Sony-designed fan delivers efficient cooling and whisper-quiet operation (22dB).
HDMI Inputs x 2 :The VPL-VWPRO1 BRAVIA SXRD 1080p Home Cinema Projector offers two HDMI inputs (up to 1080/60p capable) that deliver uncompressed digital video over one cable (cable sold separately).
Various Analog Inputs : The VPL-VWPRO1 features various analog inputs including YPbPr Component, S-Video, Composite video, and a PC input (D-sub 15-pin) for easy connection to a wide variety of video sources.
RS-232C connectivity : RS-232C connectivity enables operation of the projector using a home theater automation controller.
BRAVIA Sync : BRAVIA Sync gives you one-touch access and control functionality other over BRAVIA Sync compatible equipment using the projector's remote and on-screen display5.
RCP (Real Color Processing) function : RCP (Real Color Processing) function allows adjustment of specific colors on the picture without changing the overall image's color and hue.
Functional Cosmetic Design for Home Theater : The VPL-VWPRO1 features a sophisticated yet functional design, with a dark exterior that coordinates well with home theater environments.
