Originally Posted by 703
I've looked at the two competing models
JVC gives you more flexible placement options (motorised lens shift and zoom)
JVC have better native contrast and better blacks
Sony have a more accurate color gamut (can get very close to Rec.709)
Sony have sharper lens and therefore a shaper picture
Sony does fast motion handling a bit better
How was the brightness comparison between the two? I am leaning toward the Sony right now, but the brightness level could be the deciding factor. I like the motorised lens shift and zoom, but I would only use it once for the initial setup, so could deal with the manual instead of motorized.
. The other projectors were also projecting on a white wall, so that's a constant. I used AVIA to calibrate the brightness, sharpness, color saturation, tint, red, blue, green, etc.
I wonder if it uses the network? But does it even have an Ethernet port? Damn, I'm a bad owner, I don't know what it came with or what's back there! I was so excited to get the projector, I rigged it up, connected the HDMI out from my receiver and haven't looked at it since (or even at the CD or remotes that may or may not have been included) - too busy enjoying watching it.
