AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Optoma hd70. Color issues!!!
post #1 of 3
So I have researched and come to find out that everyone seems to have the color flickering and powering down issue. I solved that problem by simply placing a fan close to the pj. But now I have an entirely new problem. I seemed to have lost or have a lack of color. Red and green to be specific. When I try to adjust the tint and/or rgb gain/bias I can get red to be maroon and the green turns to an Orangish color. I am wondering if this could be due to dust or if the color wheel is shot? Should I take it apart to clean? Any advice is greatly appreciated.
post #2 of 3
My menu colors are fine by the way. I have tried different components and all have color loss. Even just viewing pics the color is off.
post #3 of 3
We need a lot more information about the projector.
How old is it, how many hours on the bulb, what input are you using, if you switch to s-video does the color stay the same, have you tried changing the cable, have you changed the DVD player, was it a sudden color loss or gradual...
Set all the RGB gains and cuts to zero, set the COLOR and TINT control to zero, put up a set of color bars, which of the colors looks off?
