AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Need Help Before I spend on This HT.
post #1 of 2
Hello Everyone,
I am looking to start with Entry Level System 2.1 HT. My Purpose is 60% Movies and TV, 30% Music and 10% gaming.
I will be using this system in my Apartment Living Room Size 12’X10’.
For Speakers I am going with Polk Audio Monitor50 Series II from Newegg @ 79.99 each Shipped.
newegg.com/Product/Product.aspx?Item=N82E16882290205
For Sub I am Looking for these two options
BIC America F12 Sub from shopblt.com @ 181.77 Shipped
shopblt.com/cgi-bin/shop/shop.cgi?action=enter&thispage=01100400U0212_BT46359P.shtml&order_id=!ORDERID
Or
Dayton SUB-100 HT Series 10" 125 Watt Powered Subwoofer from Parts-express.com @ 124.99 Shipped
parts-express.com/pe/pshowdetl.cfm?&Partnumber=300-633&scqty=1
The Reason I m thiking F12 is that It might be more Bang for the buck than Dayton and It is costing only $56 extra and I think I still can keep it when I am upgrading my system considering I will be moving to a house after 1 year .
I need suggestion on AVR that will work with this speaker setup.
Budget is $250. Might be able to stretch a little depending which Sub I buy.
Thanks Everyone and Merry Xmas.
And I want to Order it today so early response will be helpfull.
So Far I have Found these two options
Pioneer VSX-820-K 5.1 Home Theater Receiver @ 217 from Amazon
Onkyo TX-SR508 7.1-Channel Home Theater Receiver (Black) @ 248 from Amazon
post #2 of 2
for speakers and sub I think you'd do better looking on Audiogon.com for good deals. the receiver sounds fine
