Please, see the following videos which clearly demonstrate
white balance problems of Panasonic xx700 series.
Perhaps the most interesting is the demonstrated connection
with built-in ND filter in Part 3. Briefly said, there is no bondi blue
hue of sky if one shoots with aperture values lower than f/2.8,
i.e. without built-in ND filter. For more details see descriptions
attached to videos on youtube.
Panasonic HDC-TM700 White Balance Problem - Part 1http://www.youtube.com/watch?v=EZtP9kv_OKM
A slowed-down demonstration of TM700's inability to hold
manual WB setting in daylight. Approx. one second after manually
adjusting WB, it changes. In this demonstration, the effect is visible
as a shift of clear sky hue from blue to bondi blue. In order the effect
to be clearly visible, manual WB was set using clouds. Of course, the same
happens if one uses white sheet of paper or grey card. Thus, it is impossible
to manually set correct WB in daylight.
Panasonic HDC-TM700 White Balance Problem - Part 2http://www.youtube.com/watch?v=0zKXB5OfkIU
This video is a short and detailed demonstration of TM700's inability
to hold manual WB setting in daylight. Shutter speed and aperture values
are shown for each shot.
Panasonic HDC-TM700 White Balance Problem - Part 3http://www.youtube.com/watch?v=g20oB6faYvY
This video shows that TM700's WB problems are somehow related to built-in
ND filter. Looking into camcorder lens one can see, that iris closes from
OPEN (f/1.5) to f/2.8. From aperture f/2.8 to f/5.6 iris does not move,
but built-in ND filter shows itself at 2.8, being fully inserting at f/5.6.
From aperture f/5.6 iris closes again, stopping at f/8.0 in automatic iris mode.
It means, that all aperture values from f/2.8 up use built-in ND filter.
This video demonstrates that all applicable WB settings in bright sunlight
(AWB, WB preset Sun, manual WB)
work well without the built-in ND filter,
i.e. with apertures less then f/2.8, and shows blue sky as blue. However,
from f/2.8 to f/8.0, all of them show bondi blue cast on clear sky. The effect
is particularly strong from f/5.6. When shutter speed is changed so that iris
opens to value f/2.4 or less, bondi blue cast is not seen again.
I encourage owners of 700 and 900 series to check this issues with their own
units. Panasonic should provide us with firmware update to fix this problem.
Regards
2rm
