Some data.
Near Field SPL Raw
Near Field Quick EQ 1. -5dB 25hz Q=2. -
25hz -5dB q2@34hz; -4dB q7 @50hz -8dB; q5 @60hz -9dB Q 8. 48dB 13hz L/R; HPF 48dB 70hz L/R.
Glitch in above was an REW glitch that went away the next run
Near Field Raw EQ 1 mic moved to listening position - NO EQ CHANGES
Again that curve IS The SAME EQ (NO CHANGES for room EQ) applied at Near Field with mic at Couch position, Two Wreckers
The above three curves overlaid on each other
19hz SPL from listening room UN CORRECTED C weighting curve 2 wreckers (Room is huge - and not great for loading)
Add ~ 7.5dB for C weighting.
25hz SPL from listening room UN CORRECTED C weighting curve 2 wreckers
Add 5dB for C weighting.
This is testing with the Omni Mic for measurement through REW 5.01 Beta 13. The OmniMic is clipping too hard to get clean SPL curves.
I will update as I dial it in, and get the clipping ironed out.I will also detail the room so you don't think this is a ... disappointment SPL wise.. The room is a BASS SUCK...
Edit:
The layout living / kitchen / dining area is an open floor plan. I don't have a dedicated HT - it's our living space too. 800+ square feet floor space, 10' ceilings. 8,000 plus cubic feet loaded. Sub optimal listening position (reflection right behind head) and woofer loading. Layout sketch is below.
Edited by dB-Kicker - 1/29/13 at 9:49am
