AVS › AVS Forum › Audio › Speakers › Have a look at these Beauties!!!! How to make your OWN "High End" Cables!!!
Have a look at these Beauties!!!! How to make your OWN "High End" Cables!!! - Page 51
post #1501 of 2770
Those cables look nice Jesster. Is that the desert camo techflex? I've been hoping that someone would post a close up picture of that flex for a while. What do you mean you "curled the ends"?
post #1502 of 2770
post #1503 of 2770
These are my XPA-5 interconnects
post #1504 of 2770
My ONKYO 5508 and XPA-5 Power cables
post #1505 of 2770
Yes, that is Desert Camo. My basement has earthy tones so I think it matches very well. I'll take a close up macro shot of it so you can really see what it looks like.
I meant to say crimped instead of curled. See how the cable pants swirl up to the banana plug. I did that by crimping the actual cable underneath. I just made another set a different way. I think it looks better and I will post pics later on. I used the Emotiva heat shrink over half of the banana plug.
post #1506 of 2770
did you make those power cables, or just dress up an existing cable?
ps, you've got pm.
post #1507 of 2770
I make my own stuff. I hate electronics with cords too long or too short.
post #1508 of 2770
Dammit start making power cables!
post #1509 of 2770
It's not hard. I don't mind helping anyone out.
post #1510 of 2770
It's true! Thanks nezff, I'll be making my own power cords next.
I'm re-doing my speaker cables from the pic I posted, I want them looking just right (according to me of course). I dig having the different options to "color" up my speaker set up.
post #1511 of 2770
Belden 14/3 power cable, wattgate ends, clean cut black and some heatshrink.
post #1512 of 2770
are those gls audio locking bananas gold plated, just curious as the website is unclear.
post #1513 of 2770
I'm assuming they are. They are definately gold though.
post #1514 of 2770
I'm using Furez 10awg, should I get the PE 10mm pants or 11mm pants?
post #1515 of 2770
I know the 10mm works good on the 12 gauge. I just bought some belden 10 gauge, so I will have to let you know. Im assuming the 11 might work better by the time you put flex on it.
post #1516 of 2770
Does the 9mm work good for 14AWG?
post #1517 of 2770
They actually will all go over 12 and 14 gauge, but you have to take into consideration how tight do you want them after the flex or whatever else you apply. My thing is, when I make them, I dont the pants being so tight that you see anything underneath them showing through. I have 9,10, and 11mm pants here and i tried them on 12/2 and 14/4 and they go over them, but like I said, give yourself a little room to play with.
post #1518 of 2770
Attachment 229802
post #1519 of 2770
According to Mr. Sunda " Yes, they are 24k gold plated."
post #1520 of 2770
I have the GLS wave flex plugs like nezff showed a pic of and I can say that the plating is very good. One of the plugs I got was not perfectly round and didn't want to fit right in my binding post. I'd guess they got bent in shipping, but I worked it over with a pair of pliers to make it fit better and even after doing that the plating looks fine.
post #1521 of 2770
Nezff,
Do you have links to the components you use for your power cables? Would 12/3 or 10/3 be a improvement over the 14/3 you use?
DyeLooper
post #1522 of 2770
You can always use the Belden 12/3 but cost more.
http://www.parts-express.com/pe/show...number=100-790
I use Belden 19364, but the guy I bought it from is no longer selling it.
You arent going to see a improvement. Most if not all AVRs/prepros use 14 gauge.
http://www.revolutionpower.com/p/Bel...64-14-AWG/205/
post #1523 of 2770
Another I made a long time ago for my eD sub.
Attachment 229843
post #1524 of 2770
I think I will look at work to see what we have around wire wise. I do have a good link to heat shrink. What about ends would you suggest.
post #1525 of 2770
post #1526 of 2770
How do you feel about the :Ferrite Core 3/8 Cord Noise Suppressors? Need? Not necessary?
post #1527 of 2770
Never used them. That would be up to you.
post #1528 of 2770
I'm thinking of getting some GLS plugs. Wondering if anyone is using their new "Flex Wave" (sawtooth style) plugs and how you feel about them compared to the GLS locking ones?
post #1529 of 2770
I like the locking ones the best. The flex wave plug creates a pretty tight connection though. I am just partial to the locking ones because I have good luck with them so much.
post #1530 of 2770
these are also a great product
Not sure how many of you like spades
  Back to Forum: Speakers
