AVS › AVS Forum › Audio › Speakers › Have a look at these Beauties!!!! How to make your OWN "High End" Cables!!!
Have a look at these Beauties!!!! How to make your OWN "High End" Cables!!! - Page 58
post #1711 of 2773
Subscribed.
Great thread tho!
post #1712 of 2773
Love this thread - I've read the first 30 pages, and the last 5 pages so far...
I'm probably going to be making some cables of my own in the near future since I will have some leftover 14g in wall Monoprice cable.
I like the look and the price of the Emotiva kits ($4.99 per cable now) - I'm just curious about the size of the shrink wrap pieces in the kits. Will it work well enough on 14g cable, or should I go a different route?
EDIT: to clarify - I've seen a few people using the kits to make their cables, just want to make sure the kits will work on 14g.
post #1713 of 2773
Doing it yourself is easier because you can customize everything.
post #1714 of 2773
You guys are making some nice cables. I ordered some furez 12/4 and made some cables for the main and center speakers. Doubled the wires to make them 9/2. Figured with pushing 400 watts the extra wire would be good. These cables replaced some canare cables I made several years ago. Very pleased with the outcome. Highs are very clean and clear as are the mids and the bass is tight and full. Soundstage is wide and deep. Forgot to mention, used the furez gold bananas.
Cable
http://www.douglasconnection.com/Fur...-Raw-FZ124.htm
Bananas
http://www.douglasconnection.com/Fur...ZTSTSB60Au.htm
I'll try to take some pictures soon.
post #1715 of 2773
wow. not knocking on you, but thats alot to pay for bananna plugs and wire.
post #1716 of 2773
That's nice looking stuff, esp the 12g wire cover, but pretty expensive indeed.
Comparitively speaking, 170. per 100ft of that nice looking wire, 67. per 100 for Monoprice 12/4.
30. per pair of your bananas, 4.99 for emo kit/4 bananas, pos/neg wire covering and heat shrink tubing. Massive savings.
post #1717 of 2773
Yes know it was somewhat expensive, but I liked the specs on both the wire and bananas. Did some research before making the final decision on this furez stuff and found it to be better than anything else. Of course it's very inexpensive compared to other equal quality wire. One of the things that impressed me was the flexibility of this cable. The bananas are also top notch. Yes I could have spent less but wanted very good quality. When I ordered my stuff there was a 20% off sale, so did get a price break. All said and done, including shipping sleeving and heat shrink, have about $190 in these 3 cables. I know they were well built, know they sound wonderful in my system, and I'm happy. To me it was worth it.
post #1718 of 2773
the wire, yes maybe. but WOW the bananas?
post #1719 of 2773
LOL Yes the bananas were somewhat expensive, but when compared to other upper end bananas like WBT and Furutech they are more bang for the buck. They are made of copper with a heavy gold plating and hold almost as well as the locking type. WBT's would have been between 35 and 50 per banana and a little less for the Furutech's. Could have gone with less expensive brass ones but wanted copper.
post #1720 of 2773
I have some old canare 4s11 wire sitting around and I would like to dress it up. Will the 2 - 14 guage conductors fit into one 10 guage pant?
post #1721 of 2773
I would say no. Usually the legs dont get much wider if at all, just the bottom.
post #1722 of 2773
Got my 20 pack of GLS locking bananas in the mail yesterday. Waiting on my order of Furez 10-2 and 12-4 cable. All I need now is to find some decent RCA interconnects from my BDP-09FD to my receiver. Can anyone suggest anything where the whole thing is not made out of 24k gold and costs 10k? I don't want to use the bare minimum crap RCA cables that come packaged with everything, but I don't want a 2nd mortgage either. Suggestions are welcome.
post #1723 of 2773
Bluejeans cable
post #1724 of 2773
Monoprice's RCA cables are priced very nicely. I used to use a set of the premium component video cables and they worked well enough for me.
post #1725 of 2773
Specifications on copper wire, beyond the gauge, are meant to justify a high
price. 'Oxygen-free' wire doesn't provide any better conductivity, although the
process of making it so tends to reduce oxidation and this is probably a good
thing.
Copper wire is copper wire. Anything else is snake oil.
post #1726 of 2773
they are a little too stiff for me.
post #1727 of 2773
Cable
Bananas
Avoutlet has the furez speaker wire a bit cheaper. It's where I found mine.
post #1728 of 2773
for those wanting to see the gloss shrink:
Attachment 235815
post #1729 of 2773
Looks great! Where do you find it?
post #1730 of 2773
Can't decide if I like this better or not.
post #1731 of 2773
It basically blends in with the pants now. Perfect for those wanting the finished look but not so pronounced.
post #1732 of 2773
Yea, I wonder how it would look with the flat shrink and some flat black pants.
post #1733 of 2773
I prefer the glossy look as well. It looks more like what the outer jacket is on most cables. To me, the flat/matte shrink looks like plastic that has been weathered/exposed to UV light or some such. I should be getting my Furez 10-2 and 12-4 in either today or tomorrow. I'll post pics whenever I get them in.
post #1734 of 2773
Great point
post #1735 of 2773
I know wirecare.com sells the gloss shrink...don't know who else
post #1736 of 2773
its techflex special shrink.
I noticed monoprice has went up on their wire also.
post #1737 of 2773
Received my Furez 12-4 and 10-2 cable in the mail today. Photos follow, along with my shiny new GLS locking banana plugs for size comparison:
12-4 Cable:
http://imageshack.us/photo/my-images/20/img1026k.jpg/
http://imageshack.us/photo/my-images/838/img1027bv.jpg/
http://imageshack.us/photo/my-images/822/img1029hj.jpg/
10-2 Cable:
http://imageshack.us/g/40/img1039zn.jpg/
GLS locking banana plugs back cardboard insert:
http://imageshack.us/photo/my-images/6/img1032ya.jpg/
http://imageshack.us/g/515/img1033er.jpg/
Gonna order up some glossy heat shrink, cable pants, and some techflex, and we'll see where it goes from there.
post #1738 of 2773
12-4 Cable:
10-2 Cable:
Looking good SuckRaven! Now the real fun begins putting together your cables Look forward to your impressions when you get them in your system.
post #1739 of 2773
I looked all over for it and only wirecare seems to have it but I think there shipping is absurd
post #1740 of 2773
$10 for my order.
  Back to Forum: Speakers
