Originally Posted by p3Orion
Is it easy, straightforward to cut a cable in half to make two equal length cables? With my current setup, where the AV rack is on the left I need a ~12 ft cable for the right speaker. I'm looking into getting an AV furniture stand that would hold all my components, which would make a longer cable unnecessary. I could then make two 6 ft cables, use one for the right speaker and save the other for if/when I get a center.
Yes, that should be pretty easy, do the ends of your speaker cables have terminations (fittings, plugs, etc)? If not, easy-peasy... If not, harder - but even radio shack terminations can be just fine... Or like me, you may like to twist the strands together, and then solder them to make them stay stiff/together.
I am going to need another 100FT to complete my 7.0 runs.
