AVS › AVS Forum › Audio › Speakers › Have a look at these Beauties!!!! How to make your OWN "High End" Cables!!!
Have a look at these Beauties!!!! How to make your OWN "High End" Cables!!! - Page 74
post #2191 of 2768
Originally Posted by GusGus748s View Post
If I was you, I would try to measure the diameter of the 16 gauge cable, and that will pretty much help you decide what size sleeve to buy.
Ok once I measure it. How do I figure which size to buy?
post #2192 of 2768
I've received my 12AWG CL2 wire, GLS Audio locking banana plugs, and 3/8" techflex, but won't receive the wire pants and heat shrink until Monday. I'm dying to hook up my new speakers. So the plan is to use what I have now to hook everything up. As far as making it easier to make the cables once I get all the parts, would it be better to use only the wire and banana plugs or use the wire and banana plugs with the techflex? I definitely want to use the banana plugs now.
post #2193 of 2768
What was the circumference? If you have it in inches convert it to mm by using google.
post #2194 of 2768
Am I using the entire enclosure ( both black and red inside the outer covering) or each individual wire?
It comes out to just shy of 1/8 an inch
post #2195 of 2768
Sorry, I just go off work, and I just got home about 10 min. ago. Use a piece of thread, go around both black and red wire. Then measure whatever length that you used and see what you get. If you still get 1/8 inches that will be 3.175 mm.
post #2196 of 2768
I believe each strand of 16 guage speaker wire is approximately .05 inches, which will make each strand approximately 1.27 mm. So, for both strands will be 0.1 inch, which is 2.54 mm, round it off to 3 mm. So, in theory you should be able to use 3 mm speaker wire cover, as for boots you will need these http://www.knukonceptz.com/productdetail.cfm?prodid=SP16.
If you go under specifications, the knukonceptz boots are .29 inch for the input, which is 7.366 mm. Therefore, you should be able to use boots with an input of 8 mm. The 9 mm will probably work, but it will not have a snug fit. Hope that helped.
post #2197 of 2768
Helped a ton!!! Thanks you. I'll order and try to make them once they come in. smile.gif
What size techflex do you recommend for 16?
post #2198 of 2768
I think 1/4" should work since it will expand from 3/32" to 7/16."
post #2199 of 2768
thank you very very much! I will post pics when I am done since I ma not sure anyone here has used 16 awg. I have very short runs so I am not worried about the guage issue. I want to try to build these on the cheap, so I am using what I already have on hand (hence the 16g in-wall wire)
smile.gif now what color techflex hmmmm
post #2200 of 2768
Anyone?...Anyone?... Bueller?... Bueller?... Bueller?
Seriously, I could use some input. I have never made cables before so I can only visualize the process. I want to know if putting the techflex over the wire now, with just the banana plugs, would make it more difficult to add the wire pants and heat shrink later. The alternative is to use only the wire and banana plugs until I get the other parts. Which way would you do it?
post #2201 of 2768
Yes, you can do that!
Put the flextech over the wire, secure one end with electric tape, strech the techflex by pulling it from the end with the electric tape towards the end that is not secured yet. That way you will ensure the techflex is snug (not loose in the middle), then secure the other end with electric tape.
Then you can add your banana plugs and you are ready to go (is not going to look nice, but it is just a temp solution).
When you receive your cable pants and heat shrink, you just need to remove the banana plugs to expose the speaker wire, then you insert the cable pants right over the speaker wire and techflex. Yes, you will need to leave a portion of the copper wire visible at the end of the cable pants, so you can use it for the banana plugs. If your cable pants fits perfectly, then you might not need to install heat shrink.
I hope this helps!
post #2202 of 2768
Putting the Techflex over it now won't make it any more difficult, the issue is just that it might fray on you (depending on what kind you purchased) or might not stay very well. Either way will work really. Literally the only issue is making sure the techflex doesn't fray. You could use tape to hold it secure until the heatshrink comes in if you'd like.
1. cut speaker wire to length
2. add techflex onto wire and cut
3. Splice the outer jacket back to expose wires
4. add heatshrink over techflex ends
4. add cable pants
5. You can splice/expose the wires now OR in step 3...either one works fine.
6. Add banana plugs
DONE
Edited by ousooner2 - 1/11/13 at 7:56am
post #2203 of 2768
Thanks guys. To keep it simple I think I will use only the wire and banana plugs for now. That way I don't have to worry about the possibility of the Techflex fraying (I bought the original in carbon), which was the main thing I am concerned about. When I get the rest of the parts I will do a ~1ft practice cable.
post #2204 of 2768
post #2205 of 2768
post #2206 of 2768
post #2207 of 2768
Yes. Mine are great
Pics can be seen on previous page
post #2208 of 2768
Originally Posted by ousooner2 View Post
Yes. Mine are great
I have them as well. They look great. Fit nice and snug in my pioneers
Sent from my SGH-I777 using Tapatalk 2
post #2209 of 2768
Same here. Those Sewell deadbolts are some great banana plugs and a great value. Nice design in not needing a screw driver.
Edited by XStanleyX - 1/11/13 at 7:50pm
post #2210 of 2768
post #2211 of 2768
http://www.amazon.com/gp/aw/d/B004CM4A58/ref=redir_mdp_mobile
How do these look?
Those are the exact same ones I am using. They look great and fit nice and snug into my speakers and receiver. I am very satisfied with them.
post #2212 of 2768
Awesome! I just bought hem. Now waiting for my million deliveries to come wink.gif
post #2213 of 2768
So far with my first wire. Until the pants and banana come in. Btw this is 16awg in wall. I had a bunch left over so figured I make it with these first
post #2214 of 2768
I believe I've used similar techflex and had issues with the gold part separating from the rest of the techflex.
post #2215 of 2768
Oh no. Hope that doesn't happen
post #2216 of 2768
I ended up buying 100FT of something else lol. Something named Premium Expandable Braided PET Sleeving from Installed Depot on ebay. For 100FT cost me $24 shipped. I am hoping it is of good of better quality as the FlexTech stuff. I will report back with comments, opinion and pictures when I get it biggrin.gif
The ones from Hong Kong look good too, but it would of taken more than 3 weeks to get here, and I don't think I can wait that long.
post #2217 of 2768
I am having a hard time deciding in between these two banana plugs:
http://www.amazon.com/Sewell-Maestro-Banana-Connectors-Pairs-12/dp/B004CM4A58/ref=sr_1_10?s=electronics&ie=UTF8&qid=1358220255&sr=1-10&keywords=banana+plugs
http://www.amazon.com/Sewell-Deadbolt-Banana-Fast-Lock-Technology/dp/B006U3O566/ref=sr_1_1?s=electronics&ie=UTF8&qid=1358220255&sr=1-1&keywords=banana+plugs
I like the black chrome and security screw of the first one, but I've never used security screws banana plugs. So, I am not sure if that is better or not. Anyone care to post some pics of you've got any of both? Thanks.
post #2218 of 2768
I have a bunch all the exact same as the silver style Nakamichi ones on the left side of your first pic, for some reason he has 2 different types in the same auction? I like the Nakamichis because the 12g wire fits good, the 2 set screws hold it good, and they were cheap. I have a friend who I helped put plugs on his system and they were similar to the Sewel plugs in your other link, I didnt particularly like the way you have to have the wire just out enough to swirl/twist over the end, I stabbed my fingers a few times with the short wires trying to twist them.
post #2219 of 2768
I know what you mean. I am currently using the Monoprice ones, and they are okay, but they bend easily, which cause a few of the red and black banana plugs to touch causing my AVR to over heat and going into standby mode. After I bend them back everything worked fine. I was looking at the Nakamichi as well. I need 28 pairs for my 7.1 system, and I can get 30 pairs from Nakamichi for $30 dollars, which isn't bad. I will look into the one that have double security screws. However, I do like the black chrome from the Sewells.
post #2220 of 2768
I also like the black chrome ones like the sewels you linked, I just may buy a set of them to make my custom wires to run from the AVR to the 7.2 wall plate.
I bought this set of nakamichis off a dude in Hong Kong and they were here in about 2 weeks, sooner than I thought actually.
http://www.ebay.com/itm/270683548580?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
The ones I helped my buddy put on were the monoprice ones actually. His are all steel on the outside also, so to make sure they never touched and shorted out or anything like that, we put some heat shrink I got from work on the bodies of the plugs to act as an insulator.
  Back to Forum: Speakers
