AVS › AVS Forum › Audio › Speakers › Have a look at these Beauties!!!! How to make your OWN "High End" Cables!!!
Have a look at these Beauties!!!! How to make your OWN "High End" Cables!!! - Page 75
post #2221 of 2773
Originally Posted by Slingblayde View Post
I also like the black chrome ones like the sewels you linked, I just may buy a set of them to make my custom wires to run from the AVR to the 7.2 wall plate.
I bought this set of nakamichis off a dude in Hong Kong and they were here in about 2 weeks, sooner than I thought actually.
http://www.ebay.com/itm/270683548580?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
The ones I helped my buddy put on were the monoprice ones actually. His are all steel on the outside also, so to make sure they never touched and shorted out or anything like that, we put some heat shrink I got from work on the bodies of the plugs to act as an insulator.
I believe these ones are the same correct? 30 of them for $22 dollars isn't bad.
post #2222 of 2773
I just received the 100FT roll of speaker wire sleeve. Let me tell you for only paying $23 dollars for this stuff it looks and feels just like FlexTech stuff. I ended up ordering the 3/8" rather than the 1/2" that I used for my front speakers. Let me say that the 3/8" works much better with the Monoprice 12 guage CL2 speaker wire. It fits snug without stretching.
I will be ordering new banana plugs as well. Most likely the nakamichis since I can get a set of 30 for less than $30 dollars. I was going to go with the Sewells, but I would have to spend more then $30 dollars to do my whole 7.0 set up.
I am getting ready to go to work at the moment. So, I will not be able to do my cables until tomorrow. I will post pictures as well.
post #2223 of 2773
Here's my photo contribution:
7ft & 12ft Speaker Cables - 12AWG CL2 wire, 3/8" Techflex in carbon, GLS Audio Locking Bananas, 10mm wire pants, and 1/2" 3.1 heatshrink
post #2224 of 2773
post #2225 of 2773
Looking good. How do you like those banana plugs? I'm looking for some to replace my monoprice banana plugs. They bend too easy.
post #2226 of 2773
GusGus748s,
After reviewing this thread, I built cables using the GLS locking banana’s. For my situation, I really liked them. I love the double screw, so the wire never separates from the plug and the locking feature as I move my speakers on occasion to clean. The fact they look sharp is an added bonus.
They are admittedly not the cheapest (alas, I have bought cheaper in the past, and am I money ahead? Definitely not!) and they are long. If you want a speaker or receiver flush to the wall, be aware these stick out a bit. Again, for my set up, length was not relevant.
The short answer—I would buy them again in a heartbeat.
post #2227 of 2773
Here is my DIY cables: Kimber 8PR 10AWG terminated w/ GLS bananas & Sewell spades.
post #2228 of 2773
Does anyone know of a place that sells these, assembled, in white? I need 3 for my fronts and center and don't really feel like making them myself.
post #2229 of 2773
Thanks for the comments. My speakers are not really close to the wall, so I suppose it would be okay. I don't know if I can convince my wife that I need them lol.biggrin.gif
post #2230 of 2773
Mmmm. Licorice.
post #2231 of 2773
Mmmm. Licorice.
The flavor could have been enhanced if iced with FlexTech .
post #2232 of 2773
Ok guys, I need your input. I am searching for some banana plugs because Emotiva no longer sells their kit. I already have DIY cables, compliments of my man cr136124 using the Emotiva plugs. But, I still need to do a center channel run. I need to find something out there that is just as sexy as the Emotiva plugs. Most of what I've found with Google searches are just average looking plugs. Let me know what you've found out there. I appreciate it.
Closeup of Emotiva banana plugs
Cables to main speaker
post #2233 of 2773
Personally, I use Pomona dual banana plugs, because they fit tight and you cant short them out.
If you want sexy....can't help you there...lol.
post #2234 of 2773
I'm using GLS Audio locking banana plugs, but looking at the Pomona link I wonder about retrofitting the GLS Audios with a plastic spacer to prevent shorts. Any ideas?
post #2235 of 2773
This always gives me a kick, who ever looks at their plugs once you set the system up.
post #2236 of 2773
Mmmmeeee!
One of my front speakers is next to a door, so home made speaker cable and banana plugs are visible (see post #2177)
post #2237 of 2773
After doing some research, reading, thinking and looking at prices for product and shipping...I ended up ordering more of the monoprice banana plugs. They are inexpensive, they work and look okay. I order some more speaker wire pants from Parts Express this time. They are out of stock of the 9 mm one. So, I ordered the 10 mm.
The banana plugs should be here by Tuesday. The pants...probably till thursday. I have enough banana plugs and pants to may be do two cables. I will post pictures of the new sleeve I bought hopefully by Tuesday.
post #2238 of 2773
post #2239 of 2773
Not too shabby, Brian!
post #2240 of 2773
Thanks holt. A little on te skinny side but its because I had a bunch of 16awg left over. I will definitely be purchasing and making a new set in the near future. I saw dark blue ones and I loved them. But that will wait until I'm bored smile.gif
post #2241 of 2773
I commented the other day about how for me the gold part started to separate from the black part, but that was only because I snaked it down the column of a speaker stand. It was a tight fit and the friction was causing noticeable stress on the techflex. Under normal conditions you should have nothing to worry about.
post #2242 of 2773
Yeah they don't seem like thy would Frey. We shall see. Like i said these are only temporary. Then I will build 12awg blue ones smile.gif I also need to "dress" up the wires coming out of my wall going to my wall mounted speakers. Might fish some tech flex onto the end and put pants and bananas on the exposed end (this jot covering the whole wire w TF)
post #2243 of 2773
This looks pretty cool Brian!
Congrats on your first run!
post #2244 of 2773
Are those nakamichi plus from eBay? How is the quality?
post #2245 of 2773
Thanks cr!! Yes they are from ebay. Super quality. Tighten down very nicely. I am impressed. (Even though deep down I want the emotiva ones hahahah)
post #2246 of 2773
I have been wanting to make my own for a while now. I was wondering where you guys were getting all the parts from. Any rec?
post #2247 of 2773
post #2248 of 2773
here is a better shot of the finished product...they were a ton of fun to make!:
post #2249 of 2773
Nice cables. Although a bit challenging, I agree, they were fun to make. Knowing that "you" made them makes it well worth the effort.
I think the only issue I had was the red and/or black wires at each end would sometimes slide forward inside the outer jacket making them too long. I had to trim them a bit so that the wire pants tucked underneath the banana plugs.
post #2250 of 2773
Those are identical to what mine are going to look like, except I have a red stripe in the Tech Flex, Looks great!
I also would like to find a stash of the Emotiva plugs for making my cables.
  Back to Forum: Speakers
