AVS › AVS Forum › Audio › Speakers › Have a look at these Beauties!!!! How to make your OWN "High End" Cables!!!
Have a look at these Beauties!!!! How to make your OWN "High End" Cables!!! - Page 93
post #2761 of 3537
Originally Posted by nezff View Post
Originally Posted by deltadube View Post
Hi Nezff.. the wave flex dont fit every hole dam.. didnt know that.. one thing about the wave flex plug if it is a bit loose in da hole .. you can insert something and expanded them to fix to a point.. like a nail punch.. or another banana..
make em real snug.. dont know the limit tho..
cheers
When i tried the wave plugs, they bary fit in my klipsch posts. They didn't bottom out so to speak.
my wave plugs work great on my denon, emo amp, and paradigm speakers.. solid contact on all..
cheers
post #2762 of 3537
Originally Posted by CruelInventions View Post
Apologies to one and all in advance, but I'm having a serious bout of schoolmarm-ism just now which I simply cannot contain any longer. To wit:
OK, perhaps I'm all alone here but this particular repeated grammatical error of yours is driving me to distraction, like the prose equivalent of nails on chalkboard. It's "an opinion", "are an ok plug" and "has an issue with me". Harkening back to 4th or 5th grade English class for a moment, the rule is that "an" should be used before words which begin with vowel sounds while "a" should be used before words which begin with consonant sounds.
Not to mention typing on an iPhone is tough but in so glad we have people who are so concerned. Thank you so much for that enlightening but idiotic approach to demean a person. I guess I should watch every post which you make to make sure they are always grammatically correct to sir.
Oh wait. Care to explain why you misspelled role playing here.
And roll-playing with other people who know you are roll-playing and who tend to be geeky like yourself is easier than roll-playing where real stakes are...
Under the bridge is where the troll food is.
Edited by nezff - 4/26/13 at 5:26am
post #2763 of 3537
cheers
That's good.
I could have not pushed them in all the way or they could have bottomed out. I had two demo plugs that I tried on rf 62 and rf 63 speakers and they were super tight. My locking plugs went in all the way and expanded for a more secure fit. Glad you like the waves.
post #2764 of 3537
I just went upstairs and tried the waves again on my emo amp and they just fall out the hole.
post #2765 of 3537
what emo amp is it?
xpa 3 no trouble with nakimichi wave flex plugs.. real tight fight.. did you try making the wave bigger by inserting a banana?
like this...
i did notice its about 3-4 mm longer than the mono price plugs..
but the contact is way better inside..
there also very light weight..
the double screw make the wire very secure as well..
post #2766 of 3537
maybe those locking bananas mechanical force is busting the inside diameter of your binding posts wide open...
that would not be good....
cheers
post #2767 of 3537
Xpa5.
I'm talking about the gls waves
post #2768 of 3537
Xpa5.
i was talking about nakamichi wave flex LOL
xpa 5 same size i would think as xpa 3..
Nakamichi works great...
cheers
post #2769 of 3537
I'm about to order all of the supplies to make the cables for my new HT set-up. I plan to follow the standard recipe pretty closely (Monoprice in-wall 12awg, 3/8 Techflex (dark purple), Nakamichi plugs, etc. I'm undecided on whether to use the cable pants or to use 1/8" Techflex and heat shrink for the leads instead. If I did this I would use Superhero Techflex for the red wire and Checkerboard for the black. I think that this would look pretty cool. Has anyone made this substitution yet? I haven't read through all 93 pages. Is there any reason that this wouldn't work?
post #2770 of 3537
There have been several examples of people using techflex like you're talking about, but not in those colors. I think that sounds pretty interesting. You could always change it if you didn't like it. If you try it, be sure to post pics.
post #2771 of 3537
I just want to share with you guys few extra cables made for my new setup:
And for "tampa frank" here is a really close-up pic of the Parts Express cable pants (really easy to work with and the finish is superb):
post #2772 of 3537
Anyone use the wave plugs from Madisound?
http://www.madisoundspeakerstore.com/banana-plugs/plugs-bp-sz-single-banana-plug-black/
http://www.madisoundspeakerstore.com/banana-plugs/plugs-bp-sz-single-banana-plug-red/
Not the cheapest out there but I like the slim profile and the fact that it's unbranded. I'm planning on using them with BJC 5000 wire and tech flex.
post #2773 of 3537
I ordered new banana plugs, tech flex, and cable pants and everything should be here no later than next week...just gotta order the speaker wire and ill be all set...my wife are moving into our first house next week weekend so this will give me a nice little project....how exciting!!!!
post #2774 of 3537
congrats on the new house.. lots of work moving hope you find the time to make your cables..
cheers
post #2775 of 3537
pick up 2 xpa 1 differential mono block amps absolutely amazing sound quality improvement with the extra power and head room..
and fully balanced signal..
but the binding post are 13 inches apart.. so i had to cut off my pant legs and strip the cable off about 5 more inches..
is there such a thing as 8 inch long pant legs and where could i get them?
thanks
post #2776 of 3537
Cruel - I think I love you. My mom was an English teacher! Thanks for caring.....
post #2777 of 3537
Originally Posted by Pure-Evil View Post
I wanted to mention, if you buy the 12 gwg cable pants i posted from KnuKoncepts they fit PERFECTLY on the shielded 12gwg monoprice "white" in wall speaker wire...and over the tech flex...very easily!!!
Are these the 12 guage 4 wire cables cl2?
I have been using some electrical tape to squeeze down the techflex on the ends of the wire, then just pull the cable pants over top of that and there you have it! DONE!
post #2778 of 3537
Originally Posted by bonginator View Post
Yep! I do the same thing with the tape first..then the pants over top.
post #2779 of 3537
It sure is nice to see this thread has become such a MONSTER! I love dropping in here and there and seeing your new creations guys!!! Keep up the awesome work!
post #2780 of 3537
post #2781 of 3537
Hello All
First congrat to everyone who posted picture, they all look great!
Second I need a little help to chose the the right products for sleeve and heat wrap.
I just purchase some Blue Jeans Cables made of the Belden 10-gauge 5T00UP with locking banana, I don't think, I can puchase some of the the Techflex that would slide over it.
What size should I puchase for the main cable and where can I find some of the heat wrap that look like this (look like one piece).
The good would be, great looking cable.
The bad, is I have to cut a weld connection (made by BJC) and solder (not too good for me due to my shake because of my little gift from the Golf war in a peace keeping mission after the the Irak/Kuwait war).
Unless someone can recommend a good banana jack that you can screw the wire for the above.
Any help would be very much appreciated.
post #2782 of 3537
Anyone?
post #2783 of 3537
Originally Posted by darthray View Post
Anyone?
I'm not sure exactly what you are asking but will attempt to help.
I use 3/8 sleeving and 1/2 heat shrink. I usually use 10mm pants but with 10 gauge you might want to go with 11.
post #2784 of 3537
Anyone?
You did!
I have no idea where to start.
So many choice of sleeve and different size and it seem there is no pants that are "heat shrink" that could forgive for errors.
All of guys cables look great, but cannot afford the shipping in Canada for try and error.
All i am trying to achive is a great look from the wall to the speaker.
Again, thank you for the reply.
Ray
post #2785 of 3537
Pants don't shrink. Heat shrink does.
You did!
Ray
post #2786 of 3537
ok so I need links for the vynal shrink wrap the end or what type of tape to hold it together.. 3/8's tubing for the monoprice 12 gauge cable?
post #2787 of 3537
You are looking for vinyl heat shrink? Are you looking for 3/8 techflex?
post #2788 of 3537
Well I sold another pair of "Evil Cables" today 8ft w/ the Nakamichi plugs for $50.00
I'm glad that you made some money from your hobby. $25 profit for each cable is not a bad investment at all. If you do it more often, it'll pay for all your home theater cables and other component. Maybe, all of us in this thread forming our own cable company. There are a lot of knowledge and working hands in here. Congratulation bud!
A BIG plus one
Without Pure evil, I would never thought to do some of my own, even if I was into DIY speakers.
Dr. M is helping me on the the side to built my own I will post pictures.
Ray
post #2789 of 3537
I will post later on how mine turn out but I will be using the the BJC 5T00UP 10 gauge.
If it all good, I will post picture , if not back to the drawing board.
Look good.
What kind of banana plugs are those?
Ray
post #2790 of 3537
Look good.
Ray
Emotiva banana plugs, which are discontinued.
  Back to Forum: Speakers
