AVS › AVS Forum › Audio › Speakers › Have a look at these Beauties!!!! How to make your OWN "High End" Cables!!!
Have a look at these Beauties!!!! How to make your OWN "High End" Cables!!! - Page 12
post #331 of 2773
Originally Posted by Hamilcar Barca
It's great. Except ... I'm an addict.
Just a month ago I was using bare wires and had no compulsions or other illnesses. Now, I'm out of control. I've sold my house, spouse, children, and even pets to buy heat-shrink tubing, cable pants, TechFlex, gold-plated terminators, and the other new necessities of life. Now, I'm hearing stunning auditory experience improvements in my head.
I'm drinking my own Snake Oil!
Lol!!!
post #332 of 2773
Originally Posted by avsnoob10 View Post
you might want to try these cable pants...
http://www.parts-express.com/pe/show...number=082-776
Monoprice 14awg speaker wire has outer diameter of 7.5 mm = 0.29 inches so 1/4" expandable techflex should do it.
Thank you for that and for reminding me to do my homework before I lay out my hardly-earned bucks. Now, maybe I can pass the test. Monoprice's site says their 14AWG zip-cord is 8.00mm x 4.00mm and I'll probably trim the pants quite short for my first cables.
Parts Express says their ID is 8mm and Monoprice says their OD is 8mm; will this still be too tight a fit? If it's close, is it safe to use a lubricant? Vegetable oil?
Is there a simple way to estimate the length of TechFlex required? An 8mm x 4mm zip-cord is 126% x 63% of a (circular) 1/4" cover. It seems to me that, in this case, I wouldn't need much more TechFlex than I have wire to cover. (Anyway, I'm building a 10' cable as a test and I'm going to get at least 25' of TechFlex.)
post #333 of 2773
I'm addicted also, Might not help the sound but man do they look better. My orders are placed for parts
Chuck
post #334 of 2773
Techflex measurements are pretty accurate as they expand in circumference and not much in length. Barring any brainfarts a 25' length of Techflex will easily make two 10' lengths.
post #335 of 2773
What's great is a bunch of people building cables they like, telling each other
what they've used and how they're constructed, and avoiding futile and
interminable arguments about sound quality.
Chuck
I've spent the last few days sulking but I'm ready again to build a pretty
cable so the sound looks better. Online vendors, ahoy!
post #336 of 2773
OK i have order some tech flex , 12AWG and some knukonceptz cable pants plus some nakamichi plugs is there a DIY somewhere of how to to this i am some what confused last night i tried but i couldnt get the tech flex to go inside the knukonceptz cable pants because the tech flex keeped on seperating got pissed of and called it a night!
Do is there anything i need do that i aint doing lol
Do i need to burn the ends of the tech flex or do i need to buy some heat shrink tubing to make it fit inside since i couldnt get it inside because of tech flex spreading going every where HELP!?
post #337 of 2773
You can heat up the ends to keep them from fraying. I did not do that in my case, I wrapped the techflex around the 12awg monoprice using a piece of electrical tape. This kept it from pushing back when I put the cable pants onto the ends. It also increases the diameter a little bit to make the cable pants a little more snug. Some other people here used shrink wrap on the ends, so it's up to you which ever you prefer.
post #338 of 2773
Cut the tech flex with a hot knife, it will seal the ends off a bit.
post #339 of 2773
Just wrap it with electrical tape then put te pants over it. Easy
post #340 of 2773
Cutting Techflex with a hot knife is best, but most people don't own a hot knife. Trimming with a scissors is fine but it can make a huge mess. If you trim with a knife or scissors do it over over the sink or into a plastic bag. If working with Techflex for the first time, cut off a 1' piece and mess around with it. Cut it, burn an end with a lighter, or practice with heat shrink or electrical tape. You'll inevitably make a small mistake your first time--make it on a "test run" before butchering a pair of cable pants or wasting a 9' piece of speakwire when you need a 10'.
post #341 of 2773
Thanks for all the help guys and yes a newbie here lol so i guess ill try taping it and snugging it up inside the cabel pants ! See how it goes
post #342 of 2773
Good luck. I'm sure it'll come out great. Post pics when you're done so we can all see! :-)
post #343 of 2773
True but by a hot knife, I just meant get a knife, get it hot with a lighter or stove and cut. Works just as good.
post #344 of 2773
Come on guys, now all ye need a someone that can print speaker designations on heat shrink to ID where the wires go... might be a way for some one to make some money.. I think it would look sharp to have the labels shrunken on the plugs them selves.
Chuck
post #345 of 2773
I haven't put anything together yet but I just got the cable and bananas in the mail. Damn BJC and GLS are quick! The bananas look great and I can't wait for my techflex and cable pants to get here.
Andrew
post #346 of 2773
ya know... I'm thinking "Experience The Darkness" is a better slogan. Thoughts? Suggestions for others?
Evil Cables.... :-D
Originally Posted by Augerhandle View Post
How about the obvious?
No responses? Was it that bad?
"Hear No Evil" audio cables
"See No Evil" Component cables
"Speak No Evil" microphone cables
post #347 of 2773
Bad? No! That's a great set of tag lines.
For an isolated tag line, though, I really like "Experience the Darkness", even if
it's not as good a fit with the "Evil" theme.
post #348 of 2773
Lol I like it!!!
post #349 of 2773
where are you getting the gls plugs from? I'm in canada so I'm not sure if that makes a difference. My nak ones are not here yet and I demanded a refund. They don't even have a tracking number on the package the dude said.
I guess I'll grab some GLS ones now instead.
post #350 of 2773
How did you get in touch with them? I'm thinking of asking for a refund too at this point.
post #351 of 2773
http://www.speakerrepair.com/mm5/mer...y_Code=locking
post #352 of 2773
I sent them an email and they sent one back and said they will let me know tomorrow if they are going to give me a refund or try to send them again lol.
I just bought the black chrome GLS plugs off of Orange County Speaker on ebay. Shipping is nuts @ $20 but the quality will hopefully make up for the shipping.
post #353 of 2773
they won't ship to canada on the site, said you have to call but no one answered when I did. Got them on ebay from same store though.
thanks for the link though!!
post #354 of 2773
We will ship to Canada and most other countries. You can call us at 714-554-8520 and place the order over the phone (Monday through Friday from 9am to 5pm Pacific time). You can also order from Amazon.com and they will also ship to most countries.
Take care,
Eric Sunda
GLS Audio, Inc.
post #355 of 2773
You might want to check earlier posts in this thread but I thought I read that the GLS on eBay are not originals. Eric Sunda from OC posted in this thread regarding it. I think they only sell through their website and Amazon.com. My point for mentioning is you might not have gotten genuine GLS connectors. Send him a PM to confirm.
post #356 of 2773
handuin,
Thanks for bringing this up. We do actually sell on eBay as well under the User ID "speakerrepair.com". The person that was selling counterfeits on eBay has been removed. But if anyone orders from us directly (speakerrepair.com) they are definitely genuine.
Honestly, we don't like selling on eBay because of their extremely high fees (among other issues), but we feel we have to. We prefer directly through our website or Amazon.com.
-Eric
post #357 of 2773
Originally Posted by GLS Audio View Post
handuin,
-Eric
I am glad you were able to get the counterfeit dealer taken care of. I didn't know you also sold through eBay, thanks for clarifying.
post #358 of 2773
Take care,
Eric Sunda
GLS Audio, Inc.
No one answered and I want them...like yesterday lol
Amazon.com won't ship pretty much anything but software and books to Canada.
It's a good thing you have a store on Ebay or I wouldn't have bought any.
I read that the place I got them from was legit, so I went ahead and ordered 28 of them. The black chrome ones are much nicer looking that the locking ones IMO.
post #359 of 2773
Very good.
But what would you call HDMI cables then?
They carry both video and audio...
post #360 of 2773
Originally Posted by wojtek View Post
Very good.
Hdmi? "lust for evil". ;-)
  Back to Forum: Speakers
