I've been playing around in sketchup and have been toying with adding a second row. The room is 17' deep and 20' wide with 7'1" finished ceiling using clips and DD with GG. I have a low support beam that is only 6'3" finished height that runs behind the main seating as shown. The projector would need to be mounted behind the beam and low. Since it's low I don't want people hitting it so I thought about putting my sub (SVS PB12 plus2) under it on top of the riser. I don't have room behind the screen wall so it would need to be in one of the front corners if not.
The extra six seats are nice but may cause more problems than they are worth with low head room. I would modify the riser so you don't step up until you are already on the other side of the beam.
I plan on 7.1 with 6" corner bass traps and 2" panels around the room that will be backlit with rope lights.
Any thoughts?
Any thoughts?
