Originally Posted by NGiovas
Thanks for the responses. Yes, they are non-IC fixtures. Keeping the insulation 3" away is not an issue. I'm just wondering about drywall and even conduit. There is nothing in the instructions for either light, so I am going to call the manufacturer and see what they recommend. If I have to keep 3" clearance above, that is going to add a lot of height to the soffit. My guess is that the drywall can probably be closer considering the can is actually designed to be mounted in a drywall hole and will be touching it at that point. The other question will be if I can use an MDF face on the soffit, or if it has to be drywall. I know a lot of people are using MDF or plywood, so I am hoping that is OK.
I'm I the same boat as u as I have said. I checked progress and Juno. I was told I needed ic rated to be touching drywall. They said insulation and dw are treated the same. Has to be ic. One company said I could be zero clearance on all sides. The other said I needed one inch I the side but zero on top. I forgot which right now! Sorry. Call them today. They were both helpful.
Also to throw something out there. What about the led's that I'm using. 5 or 6 inch can with only a 2.5" mounting depth. U use a j box only for mounting. That will save a but load of room.
They r made by seagull. It's called traverse. There is also a home depot brand. Sorry i can't think of the name. I'll get it for u or if u hop over to the " theatre mercy built" thread I got the two links in that thread like maybe 1 week ago.
Jim
. I guess I can shoot a few pictures for the faithful who check in on my progress every once in a while.
