I had promised myself I would post some pictures this week, but I was feeling lazy and didn't take any
I put more insulation in the ceiling. I also sealed more seams on the ducts. I don't know that this will make a big difference, but I have always read that you lose a lot of air inside the walls and ceilings, so I figured it wouldn't hurt. When I connected the cold air return from the theater to the main trunk, I hadn't sealed it yet. I finally went back and sealed it up. I'm still a little nervous about the air flow in the theater. I think it is mostly due to the fact that when I put my hand under the inlets I don't feel a strong rush of air coming out (there is definitely air flowing though). I guess that is the whole point - not to have a strong flow that makes noise. I am sure it will be fine. I don't have the thermostat installed yet, so I still have this zone running all the time, so it is hard to tell what it will be like.
I also did some bar area planning. I spoke with a company about keg fridges and got information on circuits, drains and overall size. I'm tempted to bite the bullet and order a new one and get exactly what I want. I'm not quite to that point yet, so I have time to make that decision.
I also started looking at pumps to put under the bar sink to eject the water into the drain pipe which is actually above the sink (laundry lift pump). From what I have read, the cheap plastic pumps they sell at Home Depot only last a few years with regular use. There is a local pump company that sells them for the same price, but they are made from brass and cast iron. I am going to look into one of these.
My friend who has been helping me with a lot of the framing, etc. wants to come by for a few hours on Friday to get some final things done before drywall. We are going to hang furring strips on the main ceiling to provide clearance for some pipes. We are also going to box in the last HVAC trunk. He also suggested bringing in some of the drywall. After the near fiasco with the delivery of the drywall for the theater (them not wanting to bring it into the basement), he suggested getting one of kids that works for him to come by and help bring some sheets down. Something tells me he is pushing me to keep moving. I guess there is nothing wrong with that.
.I put more insulation in the ceiling. I also sealed more seams on the ducts. I don't know that this will make a big difference, but I have always read that you lose a lot of air inside the walls and ceilings, so I figured it wouldn't hurt. When I connected the cold air return from the theater to the main trunk, I hadn't sealed it yet. I finally went back and sealed it up. I'm still a little nervous about the air flow in the theater. I think it is mostly due to the fact that when I put my hand under the inlets I don't feel a strong rush of air coming out (there is definitely air flowing though). I guess that is the whole point - not to have a strong flow that makes noise. I am sure it will be fine. I don't have the thermostat installed yet, so I still have this zone running all the time, so it is hard to tell what it will be like.
. I am going to wire them to a dimmer and position them over my games so that I can light them when people aren't playing, but then dim them or turn them off when people are playing.
