Even with the holiday, taking in a couple of movies, spending time with the family and even fighting off a nasty cold, I still found some time to work on the theater (OK, maybe that's not much of a surprise to the crowd that hangs out in this forum).
The biggest change in the theater is getting all of the MDF hung on the underside of the soffits and the boards for the light tray attached. The process was the same as the one small soffit I previously documented:
- I attached the underside
- cut the holes for the lights
- glued and clamped the light tray
- filled the screw holes
- lots of sanding and finishing
The sides were pretty straight forward, so I did those first with the help of my son. For the portion above the stage, I waited until my friend came over on Friday and we made 4' sections and pre drilled and hung them in place. We then drew the curve, removed the pieces one at a time, cut the edge and re-attached each piece before moving on to the next. Once all of the pieces were in place, we rounded over the edges using a small lightweight router.
I still have some sanding to do above the stage. In addition, I didn't finish the soffit in the back left corner of the room yet because I wanted to install the HDMI cable for the projector and get the power bridge completed before putting everything in place. I am just waiting for the HDMI cable to come in from monoprice and I can finish it up.
I would have started installing the veneer on the sides, but I was asking the veneer supplier about the corners and my concern over them potentially splitting. The recommended using a veneer softener before bending the wood around the corners. I ordered it last week and it should be here tomorrow. Then I can continue with the veneer installation.
I also began terminating all of my wiring. All of the wires are now trimmed and most of the connectors are installed. I discovered that I forgot to order the RJ45 keystones for the data ports when I placed my original order, so now I need to wait for those to arrive before I can finish up.
Behind the screen:
In the rack closet:
The 3 boxes on the left on the back wall are for the whole house sound. I ran wiring for 2 speakers and a control panel to 11 rooms. I ran the wiring 11 years ago and the original plan was to have the wiring terminated in a different spot in this portion of the basement. I had originally run extra length of wiring so that I could terminate them later, but with the move to this corner, all but one set was long enough. You can see in the picture where I had to splice the cable from one room to extend it into the box. I was actually quite pleased that this was my only issue considering I had no idea how the wiring would be used down the road.
I also trimmed up the last of the electrical wiring that was run into the switch boxes below the panel All that remains is to run the wiring from the panel to the boxes for each circuit. I am planning to install z-wave switches in the back of the theater below the panel and a z-wave scene controller by the door. Initially I plan to install cheap $1 switches for testing until I get everything else wrapped up. Then I will order the switches as one of the final steps.
My lighting will be broken into the following zones:
front, behind screen - 4 4" 50 watt halogen
front, screen wash - 4 4" 50 watt halogen
sides - 8 4" 50 watt halogen (4 per side)
rear - 2 4" 50 watt halogen
step lights - 2 tbd (1 per step)
rope light - tbd (considering RGB LED lighting).
To wrap things up for the week, I measured all of the walls so I can get ready to order the materials for my wall treatments. Hopefully I will get the OC 703 ordered this week. I haven't made a final decision on the GOM fabric yet, so that may have to wait until I finish the columns and come up with a final design.
Overall it was a successful week. I finished most of what I wanted to. I hope to knock out most of the veneering this coming weekend so that I can start on the columns. The one part that has me worried is wrapping the veneer from the underside of the stage soffit up and around the curved portion. I think I am going to call the veneer supplier and ask what the best way to do it is. I hope I don't have to cut and fit the pieces. I would like to have it be continuous.
One final note, if I don't post for several days, please search all of the local mental institutions so that you can come save me. I have this strange feeling that my family is plotting to have me locked up. they keep talking about how I have lost it and how I am crazy whenever I talk to them about the theater.
