I hooked up an Oppo 83 to a pre-pro via MCH analog. The pre-pro only has 5.1 in and so I set up the Oppo to downmix 7.1 to 5.1. The speaker setup is 7.1 (using rear surrounds) and Dolby PL IIx is applied. I then played a disk that identified the channels. The rear surround channels played through the respective L or R surround channel speaker. The rear surrounds remained silent. It seems to me that the down mix in the Oppo isn't doing a job as well as it can. Instead of merely redirecting the rear surround to its respective surround channel, it should process a rear surround channel and send appropriate signals to both surround channels such that the application of Dolby PL IIx would then route the signal to the correct rear surround speaker.
Shouldn't that be possible? Do any players do that?
Ed
Ed
