I am considering using the Casco Silent Flex II ducts for all runs that enter/exit my theater area. I called them today to find a distributor, but they told me that there aren't any in my area. I asked about buying direct, but they said they can't sell to a homeowner. Does anyone have a source for these ducts?
Also, Do I need to replace all of the ducts that are in the ceiling of the theater, or only the ducts that are open into the theater directly? My plan is to tape all of the seams of the rigid ducts with metallic tape, use dynamat to quiet "popping" noises and rattles and use Silent Flex to replace ducts that are open into the room. Is this the best way to stop sounds entering/exiting the theater from the ducts?
