Originally Posted by V=IR
I don't have any experience with the Klipsch 1000 or Energy Take Classic sets. I have
mostly used Polk mid to upper level speakers, over the years, and have been very
happy with their price/performance. I have a set of RTi4's, on a high-performance 2-channel receiver. They produce a rich clear sound, that is hard to beat, at their current closeout price. Pair them with a PSW505 subwoofer, and a set of the Monitor30's as surrounds, and you've got a pretty nice setup for about $430.
The extra money can go to a center channel speaker, or another pair of Monitor30's.
http://www.amazon.com/Polk-Audio-Per...4130127&sr=1-5
http://promotions.newegg.com/NEemail...E0-_-PromoWord
http://www.newegg.com/Product/Produc...82E16882290200
Thanks for your response. Taking your idea of putting together a set as opposed to buying a speaker package, I did some playing around on Polk's system builder page and one of the results was the following:
Fronts-2 Monitor 50's
Center-CS1
Surrounds-4 Monitor 30's
Sub-PSW110
Now from some reading I have been doing on here, it seems that many don't recommend their subs saying they are pretty weak. Most say if you go with a polk sub, don't go with anything less than the 505. Now on SD many reported the BIC F12 to be very good for the money. So I did some playing around on Newegg as they have some sales going on some of these speakers:
2 Monitor 50s=$191.96 ($92.99 ea with $5.98 shipping)
1 CS1=$72.98 ($69.99 with $2.99 shipping)
4 monitor 30's=$159.98 ($79.99 each after instant $50 off-would have to have a friend buy a set for me to get both instant discounts)
Subtotal $424.92
From some reading I guess newegg had the monitor 50's cheaper in December (around $80 each), but their prices still are pretty good right now. I would have do decide soon as some of those prices end on 1/17 which doesn't leave me much time to decide. What do you guys think of that for a 7 speaker system (of course would still need to get a sub)? Of course this route doesn't leave much cash leftover for the sub. To add the PSW505 I would be looking at spending over $600 which is a little more than I wanted to spend. I see many also recommend the the bic F12. Right now google shows the lowest price on it to be $134(from a wonder electronics-not sure how reputable that place is) would put me around $550 if I can get it for that price otherwise again I would be looking at over $600. Or I go with a cheaper sub or just wait until I can spend more on the sub. Would this setup with either a F2 or 505 sub be a better 7.1 setup than the energy or klipsch sets or would I just be spending more for the same result? Just spitballing here-let me know your thoughts.
Mav
I will go ahead and pick up the 14 gauge wire since some of my runs for the rear surrounds may be around 25' and I will also pickup that coax cable you recommended. For the banana plugs or wire pins, does it matter what type I get? I have never used them before-do they just crimp onto a stripped end of speaker wire or do you need to buy a tool to put them on? Lastly, any suggestions for stands? Those ones I posted seem to have overall good reviews-some of them even stated they used them on the energy speakers. I looked a little on amazon, but I couldn't find anything less than $25 for a pair, so it seems like a good deal. Thanks again for your help.
