I've unplugged my chassis fans to confirm this, but, even on Level 1 the stock fan is 1500+ rpm and the noise is not just noticeable but loud. I almost feel like unplugging the thing. Google results are almost universally overclocked gamers who go with after market coolers, (not an option, not pulling the thing out). Any suggestions? Max CPU temp was 45.5C after letting it run (doing nothing) for about 20 minutes (on 3), currently on 1 temp is 31C.... Even when the fan slows there is a slight humming, I've double checked and it is seated correctly (checked the bottom of the board before I mounted as per Assassin's suggestion).
For now I'm not attempting the molex reduction as those fans' noise is dwarfed by the CPU fan's noise... and the CPU fan noise is normal fan spinning, not as if something is necessarily wrong with the fan.
I'm also not certain on the Molex FAQ which of the connex to swap, there are three fan to molex 'fan adapters' (x3), the fan adapters to the case's molex adapter (one piece, but a black and a red wire (x3 connectors) to the PS Molex adapter wires (4 wires, all black). However, I can wait until the GD 05 build is underway since the case is ... 'in the mail'.
Also, the blue led on the front of the case is just too bright, I can unplug it, but was thinking of taking one of my kids markers to it and coloring it like brown. Any thoughts?
I've checked all the xml text and it all is correct.
