AVS › AVS Forum › Video Components › Home Theater Computers › Assassin's Simple/Beginner HTPC Buying Guide
Assassin's Simple/Beginner HTPC Buying Guide - Page 386
post #11551 of 15907
Originally Posted by jrock18 View Post
I still need to find a good deal on a 2tb internal drive and a blu-ray writer for the optical drive. Looking for feedback/opinons/suggestions on some.
NewEgg Western Digital Elements 2TB Desktop External Hard Drive Item#: N82E16822136471 $109.99 after $50 instant savings and $20 promo code EMCNGND36 and free shipping
post #11552 of 15907
Originally Posted by assassin View Post
Guide #24 (#92 in total): Plex Server for your HTPC
Enjoy.
So, If i go buy at little Roku XD, for $69 I can stream my movies to my other TV? I see I need the more expensive version if I want it wired. Roku will stream MKV, AVI's , MPEGs???
post #11553 of 15907
I don't know about the Roku. There is a whole other forum here at AVS about streamers.
post #11554 of 15907
You can get a roku to stream, but you have to use playon which is a paid media server that has a version developed for Roku. From what I understand it is a little difficult to setup. I have 2 Roku myself.
I bought the 3TB drive at staples from a slick deal for $100 plus tax. It was an external and I just removed it from the case.
post #11555 of 15907
Well I installed Plex from your guides onto my HTPC, went to Target and bought the Roku 2 XS $99(wanted the Ethernet connection since I don't need wireless), setup Roku, setup Plex to work with Roku, and it works great to stream my movies from my main HTPC. Plays MKV's well, wont do AVI's, but I have converted almosy all my avi's to mkvs. Pretty good option to use as a extender for cheap. Only using it on a 36" LCD Sharp 1080.
post #11556 of 15907
Originally Posted by absoluteloki89 View Post
I'll be building tomorrow
AMD A8-3870k(was on sale this weekend for less than 3850 so why not.)
ASUS F1A75-M PRO FM1 AMD A75 (Hudson D3)
Corsair Vengeance 8GB DDR31600
CORSAIR Builder Series CX430 V2
Thermaltake Lanbox Lite VF6000BWS
Samsung 830 60gb
Seagate 3tb Barracuda XT
Any opinions on this build specifically processor and case? Power consumption? Also looking at buying Assassin's guides. Are there instructions for how to better manage power consumption as that is my only real concern. Also is there something that renames media for me? I have been editing it all by hand for a long time.
As far as file renaming...
I tried to use "Renamer" that Assassin recommends but it was not working for me and had limited file renaming options.
I just came across "MC-TV Renamer" it looks to have more options for renaming.
Also found "Filebot" it looks totally customizable and easy to use. Was going to set it up this week, but....
The developer of MCEBuddy worked in my ticket to save renamed/compressed recorded TV recordings to the
D:\\TV Shows\\Show Name\\Season XX\\SXXEYY - Episode Name.mp4
format that is perfect for MCM, so probably don't need to use Filebot. Newest MCEBuddy version is 2.1.4
post #11557 of 15907
For $99, you can get a used Xbox 360 that can act as a Windows Media Extender so you can watch live TV, recorded TV and watch all your mkv, avi, mp4 and all your wtv files, all with the glorious eye candy of Media Browser.
post #11558 of 15907
okay, so ive followed Assassins guide word for word.......and i can't get HD audio to bitstream Properly.
system: i3 2105, 4gb ram, asrock h67m itx - linked via HDMI to an Onkyo TSXR308 AV receiver.
installed: w7, updated to today, mpc-hc + LAV filters, VLC 2.0
Using the raw file off assassins server (the dts MA one with the microphone whale lol).
using MPC HC + Lav filter (and yes, all the bitstreaming options ticked),
the AV receiver DOES detect DTS MA (it comes up on the front) - but mpc STRUGGLES to play the file. It'll do about 5 frames, then pause for half a second, 5 frames, then pause, and so on.
If I play the same file in VLC, and switch to spdif, it plays that same raw file in DTS only, and the file plays fine.
So basically......the bitstreaming is sort of working, but if it bitstreams HD audio it struggles to play. Why? what am i doing wrong?
im sure i've followed assassins guide by the letter! please please help assassin!
thanks in advance.
post #11559 of 15907
Im looking at building a tiny htpc with an Habey 600 case that has no room for a separate video card. Are there any Micro ITX mobo's that can do 3D?
I don't really care about 3D at the moment, but would like to future proof in case I do want to go 3D.
post #11560 of 15907
With XBMC I installed the version with the HD patch on top of everything... went to the config and turned it all on... and BAM... my amp was showing DTS Master Audio. I shed tears of joy!
post #11561 of 15907
Yes. Check the first post of this thread.
post #11562 of 15907
Awesome! That's what I want to hear!
post #11563 of 15907
thanks in advance.
What about other files? What about the more reliable file that I posted in the first part of that guide?
Also make sure that under Sound you have HD audio listed as a supported format.
This is an example. Ignore the top part but under supported formats you should have all the HD Audio listed...
post #11564 of 15907
Finally received my Silverstone GD05 today. I'd be a hypocrite if I didn't post pics of the re-build.
So here they are!
The "old" and the new. The "old" mini-ITX is being put into the micro-ATX case. No real reason to get a new micro-ATX motherboard and I really like the ITX motherboard so I am going to recycle it.
Here is the molex trick to slow the fan speed before...
...and after the mod
A view of the NVidia 430 that I installed to do little more testing. I have a 430 with a fan in another test rig. This one is fanless. Currently still using the Intel integrated though as it just works and looks awesome. I plan on switching back and forth regularly.
Here's a view of the new case. Notice my IR receiver in the top right for my Harmony One and the blue dongle in front USB for the RF of my Lenovo remote
Here's a quick shot of the setup that is used many hours a day by me and my family
post #11565 of 15907
except the little roku box is quiet can be hung off the back of a TV with sticky tape and plays MKV's a whole lot smoother..
post #11566 of 15907
a word of caution that box is a pain to keep cool. I tried it and am now using the 800 in a second build and had to take some assassin advice to drill a hole in the top for a third fan. The habey still runs 46-50 degree when watching a 1080p video file.
post #11567 of 15907
So here they are!
nice looking setup. Is that a Denon 3806 I see one of my all time favorites.
post #11568 of 15907
Yes, absolutely! Working like a champ and no real need to upgrade right now.
post #11569 of 15907
Fantastic. Very good to know.
Glad I could help get you streaming!
post #11570 of 15907
Bright minds think a like....I bought the same case this weekend! A tight fit inside but looks great!
post #11571 of 15907
looks nice !
post #11572 of 15907
Pretty good deal on a 2TB HP external hard drive (WD Green inside)
Link to drive: here
Then get a $1.85 coupon at e-junkie for $25 off $75
Total:
PM me next time you see this ....
post #11573 of 15907
except the\\ little roku box is quiet can be hung off the back of a TV with sticky tape and plays MKV's a whole lot smoother..
Yeah, I was even going to get into the issues with the XBox360. Im happy and thats all that matters right?
post #11574 of 15907
hey assassin,
i see you finally got the gd05. did the 5v mod work as advertised? i need to do that to mine, that is the only realy issue i have with the case.
nice set up bye-the-way. looks sweet.
post #11575 of 15907
Need a bit of help here if anyone can . A bit at my wits end with MB And the chocolate theme . I thought it would be an easy try just to get a known to work theme going just to see something different than that hideous blue background screen. All i ended up with was a hideous blue back round with some "film strip" icons (3) , one each that represents each recorded tv show. I have one "tv" folder with three episodes(files) of "The Big Bang Theory" . I have been through the guide 10 times and have refreshed mb that many more times . Checked and double , triple checked all the settings . NO CHOCOLATE for flocko
Anything ?
post #11576 of 15907
Originally Posted by Tizi View Post
hey assassin,
Yep. I have done it multiple times.
CPU was at 38C and its whisper quiet.
post #11577 of 15907
Anything ?
Are you talking about the background in MB or the background in WMC?
post #11578 of 15907
Anything ?
Did you try any other themes? Same issues? I had trouble setting up Chocolate also. Switched to Diamond and works great and looks awesome.
post #11579 of 15907
Hey Assassin, with plex media server is it creating it's own artwork or using the artwork you already have? Also - do you still use MCM for all your artwork with XBMC?
post #11580 of 15907
That's a good question. I will add a movie without metadata and see how it shows up.
I still use MCM for all my metadata and artwork.
