AVS › AVS Forum › Video Components › Home Theater Computers › Assassin's Simple/Beginner HTPC Buying Guide
Assassin's Simple/Beginner HTPC Buying Guide - Page 417
post #12481 of 15486
Originally Posted by Hard2Port View Post
Ouch!
Just so I am clear does this mean I have to reformat the O/S drive and re-install and configure all my apps such as XBMC, TMT, MakeMKV etc?
Yes, that is the general recommendation. Its much cleaner to do that way, i'm sure if you look around you might find an alternative but its most likely win 7 won't even launch
post #12482 of 15486
Okay cool.
Thanks for the help!
post #12483 of 15486
Originally Posted by jacket_fan View Post
Wow, I hate to ask this but, how do I switch to the Intel driver?
This solved several minor but annoying problems that I had (from the FAQ in post 3):
There is a bug in the Intel Win7 x64 HDMI drivers that can cause a blue or black screen with certain system combinations. Try this older driver (link below - sorry, don't know why it didn't just copy/paste) which has been known to fix this issue. If you connnect okay with VGA and not HDMI this is highly suspicious of confirming this problem.
http://api.viglink.com/api/click?for...13340866829433
post #12484 of 15486
Originally Posted by uncola View Post
Hey Curtis, I just got a new onkyo receiver too, mine is the tx-nr609, one step below yours.. I can bitstream just fine to it using xbmc and also powerdvd. I don't use windows media center so I'm not sure what you'd have to do for that
Uncola I don't have a problem Bitstreaming anymore. I forgot that is was a button that I unchecked in the Audio Advanced properties section that was causing the problem. The problem I have now is that is I have to Uncheck it to get Audio to watch Live TV in WMC but if I leave it Unchecked I can't Bitstream. Do you understand my dilemma? Any suggestions anyone.....
Here is a pic of the box I have to uncheck in order to watch Live TV or check to Bitstream:
Exclusive Mode "Allow application to take exclusive control"
http://www.flickr.com/photos/8317538@N06/7065551597/
post #12485 of 15486
Question for you, when you bitstream from your HTPC what settings do you use on your NR709?
post #12486 of 15486
If you are bitstreaming to your AVR you shouldn't have to check those settings. I added that portion of the guides only for those that weren't bitstreaming and were instead sending their audio directly to the HDTV via HDMI.
post #12487 of 15486
Hi all,
I am hoping someone has experienced the problem I am having and can point me in the right direction.
I am installing a new MB and CPU in my HTPC. I have built 20 or so PC's over the years so I am a bit perplexed as to what I might have done wrong on this one.
I am installing a Gigabyte GA-Z68MA-D2H-B3 and an i3 2105 as per the guides recommendations.
I get it all together and when I hit the power button the leds light up and the fans start spinning for approx 2-3 seconds then they shut down. I checked the power connections to the board and they seem right. Any suggestions?
post #12488 of 15486
Hi all,
Make sure the CPU and cooler are seated properly.
post #12489 of 15486
That was the exact MB I had as well. Did you replace it with the same or did you change to a different model? If so did you have to install all your OS and Apps from scratch again?
I just sent it off on Friday and they received it yesterday so now I have to wait for them to either fix it or send me a new board. I am certainly hoping to not have to reinstall my OS and apps.
post #12490 of 15486
Originally Posted by Alan Winslow View Post
Using Assasin's guides for build and all setup settings including Media Player Classic, I am experiencing something very strange.
I mainly play MKV files. Our setup includes 2 projectors. DLP for TV and SXRD for movies. After installing a Geforce GT430 in the HTPC the Benq W6000(DLP) plays smoothly and the Sony VW85 has a bad stutter.
The HTPC is fed into a Radiance Lumagen Video Processor to the projectors using the same settings in the Lumagen for both.
I am using the latest drivers for MPC, madVR and Cuvid.
Are there any specific preferred Drivers than the latest?
Previously the HTPC before installing the GT430 was using the built in Intel HD2000 video - i3 2100 through Media Browser/WMC and both projectors played smoothly.
Any suggestions are appreciated.
I tried tonight playing through WMP with the Nvidia card settings in the Windows Control panel and it's playing fine with the Sony Projector.
I'm thinking it has to be something with the MadVR and Cuvid processing through MPC.
Any suggestions are always appreciated
post #12491 of 15486
Looking for some clarification: assuming you have the hardware to do full 3d and the TV to go along with it, can you play a 3D MVC MKV file through any software that plays MKV, or do you need a specific player capable of playing those files? If so, what software players can play them?
I am not talking about side by side or top/bottom 3d files. I am referring to full frame MVC, specifically created from Makemkv.
post #12492 of 15486
Assassin that's not my issue! If I want to watch Live TV I have to uncheck them But if I want to Bitstream they have to be checked. I think the Lav Filter is affecting the Windows Codec when watching Live TV.
post #12493 of 15486
Try the Shark007 codec pack. Its more flexible with live tv.
post #12494 of 15486
I'm always amazed at the incredible amount of information available on AVS. This guide is fantastic Assassin! I intend on purchasing your paid guides once I've ordered my new parts. I've configured a mini-itx build and my only hesitation is the cpu fan issue in the Apex mi-008. The pentium g620 is plenty of cpu for me and I have no desire for 3D, however per your guide it will touch the psu. Does this create extra noise? Unsafe? Or not really a big deal? I'm not seeing a g620t readily available and feel like I'm spending 65.00 on a slim fan by purchasing the i3 2100t.
post #12495 of 15486
Thanks for the suggestion Assassin but I'm scared to mess with the Shark007...lol
post #12496 of 15486
Don't be afraid to go in the water.
post #12497 of 15486
Published a new guide today...
Guide 25 (#116 in total): Accessing Your Media From Anywhere in the World Using Plex Server
Have a few more coming. I also added a few to the WMC section.
post #12498 of 15486
This is your idea of "cutting back"?
post #12499 of 15486
How does this compare to Remote Potato?
post #12500 of 15486
So I am doing an HTPC build for a friend and I am using several components suggested in this thread / guide.
The two components that are posing the problem are the Antec Three Hundred Two case and the Gigabyte GA-Z68MA-D2H-B3 MB.
The case has two USB ports at the front of the case - both of them USB 3.0. There is a single internal USB cable that is meant to connect to a header on the MB. The only problem is there is not a USB 3.0 header that matches the cable on this board.
Is there a way to use the ports as USB 2 with some kind of adapter for the cable?
Any suggestions are welcome....it would be a shame not to be able to utilize those two ports.
post #12501 of 15486
That board doesn't have onboard 3.0 headers. Actually very few of the LGA1155 boards have them in that price range.
post #12502 of 15486
cburbs and I (mostly cburbs) finished part 2 of the remote potato guide tonight.
Guide 57: Remote Potato (Part 2)
I am trying to cut back. Really I am.
post #12503 of 15486
Assassin - Do you no longer recommend the Apex MI-008 for a mini-itx build? You have it in your guide yet I found another post from you saying you'd never use it again.
post #12504 of 15486
You need a motherboard that has USB3.0 headers if that is what your case has. Otherwise you need a case that has USB2.0 headers if that is what your Motherboard has.
My case has USB3.0 and my motherboard has the headers for it. The headers are much different than normal USB2.0 headers.
I am not away of an adapter.
You can always add cheap PCI-x USB 3.0 cards to add more USB 3.0 ports.
But runing the USB3.0 front ports on your case (if that is what it has) will most likely need a motherboard with the header for it.
You won't have to go without USB3.0 but you might have to go without the front ports of your case being operational unless you upgrade your motherboard.
Here is some pics of my PC build.
First this pic is of the USB2.0 headers for the front of my case
This pic is of the USB3.0 header for the front of my case.
The headers are very different.
This is the front of the case below.
Are you sure your case is USB3.0 only in front and your motherboard is only USB2.0 ?????
If so- you would need to modify your case with USB2.0 ports to replace the 3.0ports or upgrade your motherboard.
If it was me- I would just add a USB3.0 card if I needed the extra ports, or otherwise just leave the front unhooked and nonoperational for now.
Gives you a good reason to upgrade the motherboard.
Perhaps wait for a good deal on a Z77 model and sell that off or use for something else.
post #12505 of 15486
That was with clarkdale and a taller cooler. I use it with sandy bridge and the low profile cpu cooler just fine.
post #12506 of 15486
That MB has USB 3.0 ports in the rear I/O port and none on the motherboard. If you wanted to utilize those ports, you may want to look into another mb.
post #12507 of 15486
Thanks, was worried for a second there.
post #12508 of 15486
When posting earlier I thought it was a projector issue and the GT430 video card. The problem is there after removing the Card and going back to the Intel I3 2100 - Intel HD2000 video.
I'm still having a severe stutter problem using MPC. When playing MKV files using WMP through Media Browser the playback is smooth without a glitch.
I am using the LAV Spilitter -Stutter there using MadVR or not using MadVR.
Latest drivers and versions of all devices and software.
Any thoughts are appreciated.
post #12509 of 15486
I see you also posted in the MPC-HC thread which is what I was going to recommend.
I don't use Madvr as I haven't noticed a dramatic improvement based on my HDTV and the media that I use. I also like to keep things as simple as possible while still having incredible PQ.
post #12510 of 15486
I really appreciate the keep it simple thought, which your i3 -HD2000 setup is. It works great and performs flawlessly.
With the projector and 106" screen I do see an improvement in the image with the GT430 and MadVR and Cuvid.
I will keep trying to get the stutter corrected and if it dosen't work out it's not going be too bad. It's still a great setup.
Thanks for your support.
