Originally Posted by Mfusick
The 430 is lower than the 440 I recommended above.
So a 430 would be lower performance in gaming than a 6670 or a 5670 Radeon or a GeForce GT 440 GDDR5.
But nothing wrong with what you linked.
I have been seeing some good deals on the newer cards. Specifically to you - take a look at the Radeon HD 7750. It would be a step up if you wanted to go a bit higher in performance.
I would look at
GT440 or 5570/5670/6670 first. Should meet your needs.
Above that you can look at the 5770/6770 which should be higher performance. Nothing Nvidia makes really compares in performance around the $79 mark.
I would look at
I just put in a Sapphfire OC 7770 in my new build pretty slick ... $150 for the OC version $130 standard " EDIT (EDIT this Card does need a 6 pin power connector , So Make sure you have one )EDIT "
matches up well with the 77 Chipset PCI 3.0 .
But it does cost more ....than what Mfusick has stated above ^^^^^
I'm not trying to spend your money here .......& all the above cards will work
