Originally Posted by Shanndogg
Finally getting my HTPC parts in, but I really need your help on my server build to go along with it. I got the template from the Renethx guide and am going with unRaid. Here's what I'm thinking so far for a 20 drive build:
Case: Antec Twelve Hundred V3
HDD Cages x4: ORCO SS-500 5 Bay
PSU: PC Power and Cooling Silencer Mk II 750W
CPU: Intel Xeon E3-1230 Sandy Bridge 3.2GHz
Motherboard: Supermicro X9SCM-F MBD-X9SCM-F-O LGA 1155 Intel C204 chipset microATX with IPMI
Memory: Kingston ValueRAM KVR1333D3E9SK2/8G DDR3-1333 ECC CL9 2 x 4GB Kit
HBA x2: SUPERMICRO AOC-SASLP-MV8 PCI Express x4
Cable x4: 0.5m SFF-8087 to Four SATA Forward Breakout Cable (3ware CBL-SFF8087OCF-05M)
Flash Drive: SanDisk Cruzer Fit 4GB USB 2.0 Flash Drive
My question is mainly regarding the CPU. Originally I had it as a Xeon E3 1225 as in Renethx's guide, but I was recommended the E3 1230 instead since the motherboard already has a video chip. Furthermore, since I don't plan on running a virtualized served, I could save some cash and go with an i3.
Considering this will be paired with my HTPC as seen here, and that I want to do transcoding of full bluray files using Plex to Android phone/remote computers, what processor should I go with (or should I make any other changes)?
I am planning to do the transcoding from the server, but if it makes more sense to do it from the HTPC please let me know. I know a lot of you do what I am trying to set up so any insight would be great.
I am going to have to disagree with Renethx's recommendations for a server if you are using this just for your own personal use. You can go MUCH cheaper and have a fantastic server.
Now if you are if you are setting up Shanndogg.com and have a ton of server traffic that's different.
Also, I would consider FlexRaid over unRaid at this point.
they just refunded all my cash & sent me a free return shipping label ... going back to Amazon ...
