Originally Posted by
assassin
I have the HD Homerun (not the prime).
I value my time too much to mess with the XBMC pvr in its current state. Seems like a bit of a mess when WMC just works.
Will revisit it once it is easier to use.
Ok i'm confused... not the 1st time !
whaat hardware do I need now? I have DirecTv not cable & have NO OTA at all , I do now have TMT5
the HTPC's are all up & running but the software end ===> WMC or XBMC
I read some of/if not all the guides but some of that kinda went over my head on which frontend I should use .. any guidance from you guys PM if Ya want .. I do want to load everything myself & learn how to, so I don't want anyone to hold my cause it's dark outside
.. but which direction should I go ...
just gimme a quick simple reason ..
