AVS › AVS Forum › Video Components › Home Theater Computers › Assassin's Simple/Beginner HTPC Buying Guide
Assassin's Simple/Beginner HTPC Buying Guide - Page 443
post #13261 of 15486
Originally Posted by anleva View Post
Assassin,
Your guides start after the hardware has been assembled. While hardware assembly is pretty straightforward do you have any recommendations for any YouTube videos or online tutorials that I can reference once my hardware arrives and before I dig in to your guides to configure everything?
Check my FAQ. I have a good link there.
post #13262 of 15486
Perfect!
post #13263 of 15486
Assassin,
Perfect!
In addition to the links provided by Assassin, I suggest searching both for your case model (and perhpas also your motherboard model) on YouTube. You'll almost certainly find a variety of videos some of which just show you the item in detail, and others of which document builds using that case or motherboard. It can be useful to give you some comfort and a heads up for ideas and issues that you might not have considered.
I usually do that before I even order a case just to see in advance how everything goes together, to better plan my build, and to get an idea whether there might be any "gotchas" that I might want to know about before I start.
You'd be surprised how many different cases have You Tube videos. Some homemade, some by bloggers, some by places like Newegg.
post #13264 of 15486
I am not really sure if its even important.
The developer has stated in multiple different posts that this bug was supposed to be fixed in version 6 (we are now on version 7).
I am unbuilding my entire array just to deselect the recycling bins from each drive. Then I will rebuild. It might take most of the day today.
I haven't added any data yet to my array so I was able to quickly test this out. I performed the actions that you added (slightly modified as I had to delete my current Cruise Control configuration so I could access the drives) and did the whole recycle bin thing. Rebooted and still got the warning...
So I went ahead and entered the registry string (using "Explorer" with a capital "E") and it correctly added it to my registry as:
HKEY_LOCAL_MACHINE\\SOFTWARE\\Wow6432Node\\Microsoft\\Window s\\Cu rrentVersion\\explorer\\BitBucket\\V
It now works without any warning, so it looks like both of these parts need to be confirmed/configured correctly (registry and recycle bin).
The other string: (HKEY_LOCAL_MACHINE\\SOFTWARE\\Wow6432Node\\Wow6432Node\\Mic rosoft\\Windows\\CurrentVersion\\Explorer\\BitBucket\\V) is still in the registry. I don't know why Flexraid mistakenly put it there in the first place.
I went ahead and deleted the additional Wow6432Node and all folders within it, restarted and everything appears to be working.
post #13265 of 15486
Great idea!
post #13266 of 15486
Originally Posted by Wilky13 View Post
So even though your tuner is in your HTPC it will record to a harddrive not in the HTPC (ie. a server)?
No, I do a commercial removal and the transfer the recording to the server. I toyed with the whole iSCSI thing but soon bailed as it wasn't very intuitive.
post #13267 of 15486
I think what happens here is that since the individual drives are tied to the desktop Recycle Bin in WHS 2011 you need to tell them not to move deleted data to the OS/Desktop Recycle Bin. I think this goes into an area where FlexRaid recognizes its there but can't add it to the parity drive.
One of my drives had 21GB in the internal recycle bin that I deleted even though there was nothing in the desktop recycle bin. I think this confirms my theory.
From what I have read I think the steps I added in the guide will fix this. I am rebuilding the array now and will see if I get any errors. Otherwise I haven't read anything that this is a big deal either way but its nice to not have messages.
post #13268 of 15486
Thanks for the update- I'm curious to see if you still get the warning without adding the registry key in the right place (unless you already have it there).
post #13269 of 15486
Mine is already there. For the life of me I can't remember if I put it there or not.
That happens when you are perpetually building, testing, writing, tweaking, etc.
post #13270 of 15486
Gotcha, you should be good to go then.
How do you handle Windows Update in your WHS/Flexraid setup? I set mine to update automatically at 1am and then set all the Flexraid Update/Verify/etc. at the same times you had listed in your guide. Do you think it's better to have Windows update on manual?
I am also testing transferring over data from my NAS and was trying out Teracopy as I have seen it recommended. However, I am getting half the transfer rate as the regular windows service. Teracopy gives me about 40mb/s and windows about 80mb/s. That's a pretty big difference. I only recently heard about Teracopy, but if this is how it performs I would rather stick with Windows. I always thought that Windows would let me know if something didn't get transferred correctly, is this not the case?
post #13271 of 15486
I don't use Teracopy.
I use manual install on all my Windows Updates.
post #13272 of 15486
Yeah, I just have an HTPC right now. I toyed with idea if building a WHS 2011 server and having all
my HDDs on there but i was told WMC will not allow you to save RecordedTV to a network location, only a local HDD. So it defeated the idea of moving my HDDs out of the HTPC. But I should be okay as my HTPC case can accommodate 4 total HDDs along with my SSD and bluray drive. So right now I have 2 2Tb seagates. I can eventually have 4 4Tb HDDs for 16Tb total in the HTPC.
I share all my folders in the HTPC in my Homegroup and set my libraries on my other PC and laptop to a folder on the HTPC, so my HTPC basically is a server already.
The only thing I am worried about is I do not have any kind of raid setup. I backup important docs to an external HDD, but I wish I had a server that had 2 copies (original and raid backup) of ALL my files in case of a HDD crash.
post #13273 of 15486
And on the topic of comskip. I use MCEBuddy 2.1.9 to convert my wtv shows to mkv and commercial removal.
I've found that the last 2 seconds of the show prior to a commercial get cut out along with the commercial.
I've been tweaking the config.ini file for days now in comskip, but trade one nuisance for another.
Anyone have a solid comskip.ini file for USA broadcasts that does a good job of cutting commercials but not taking some of the show with it!
post #13274 of 15486
post #13275 of 15486
Finished rebuilding the parity drive. No issues or errors at all.
post #13276 of 15486
Excellent!
post #13277 of 15486
I am actually just using one of these -->http://www.newegg.com/Product/Produc...ard-_-59107052
With flexraid + pooling, whs2011 across the following 4x2TB of data drives and two external 3TB USB drives as my parity drives. I plan to extend so I have a 1:1 mirror at some point, but for now it's just for video and music..my biggest gripe with the turion microserver is its not that great for serving up media. I found running plex very intensive even after adding 8GB of memory. Give flexraid a try, I struggled at first but with help from the forum it's been fantastic.
post #13278 of 15486
I have this post in an old thread about TV Show renaming and folder organizing but am not getting any response. I set up Sickbeard and SABnzbd according to the guide. Any help would be appreciated. Thanks.
post #13279 of 15486
Consider using my new server guides. I try to get rid of that struggle.
post #13280 of 15486
I have actually found two things that can impact this.
1) get the donors version..pretty solid now
2) try using 43,0r 47. If 47 is too much try 43. I record mostbroadcasts seamless
post #13281 of 15486
Assassin any thought of offering all in one ready to buy servers?
post #13282 of 15486
We do that already.
post #13283 of 15486
We do that already.
Ah I missed that.
post #13284 of 15486
Woot has the SiliconDust HDHomeRun Prime Tuner
$129.99 + $5 shipping
1 SiliconDust HDHR3-CC HDHomeRun Prime 3-Tuner Network TV Tuner
Microsoft Windows 7 Professional 32- or 64-bit for $80 + free shipping
SnaggStuff offers the OEM Microsoft Windows 7 Professional 32-bit 1-User, model no. FQC-00730, for $79.99 with free shipping. Outside of the price below, it's the lowest total price we could find by $5.
A close price is Trinity Software Distribution's $80.75 via coupon code "FACETWIT5" with free shipping.
SnaggStuff also offers the OEM Microsoft Windows 7 Professional 64-bit 1-User, model no. FQC-00765, for $79.99 with free shipping. That's another price low by $5.
post #13285 of 15486
I use one of these running unRAID and love it. Still have 1 slot open. In the end it will have a total of 6 drives. 1 parity/1 running apps/4 data drives.
Sometimes that HP is on sale at Newegg. It used to be like almost once a month it would be listed at around $249 with extra ram or hard drive or whs2011. I got mine back in feb from macmall for $199.
post #13286 of 15486
I guess the version with MCEBuddy is not the donor version?? I will look into that.
post #13287 of 15486
Originally Posted by LastButNotLeast View Post
Have you looked here?
http://www.kaashoek.com/comskip/view...0caccf27cb29ab
Thanks! I will dig through this forum tonight :-)
post #13288 of 15486
That would be here:
post #13289 of 15486
I just assembled the hardware for my first HTPC. I have a Gigabyte Z68 MOBO along with the paid guides. I couldn't find any reference to the BIOS settings for this board (just the ASROCK), but I realize it's impossible for Assassin to cover all of the combinations.
Can anyone point me to a guide showing me how to set up the BOIS for this board?
Thanks in advance for your help!
CASE ANTEC | THREE HUNDRED TWO RT
MB GIGABYTE|GA-Z68MA-D2H-B3 Z68 R
PSU SEASONIC| S12II 380B 380W RT
CPU INTEL|CORE I3 2105 3.1G 3M R
SSD 64G|CRUCIAL CT064M4SSD2 R
MEM 4Gx2|GSKILL F3-12800CL9D-8GBRL
HD 2T|SAMSUNG HD204UI
BD BURNER LITE-ON | IHBS212-08 R
post #13290 of 15486
I doubt there is going to be any specific guide anywhere for your motherboard.
I would use your manual as your guide and ask questions here when they arise.
