AVS › AVS Forum › Video Components › Home Theater Computers › Assassin's Simple/Beginner HTPC Buying Guide
Assassin's Simple/Beginner HTPC Buying Guide - Page 460
post #13771 of 15526
Originally Posted by assassin View Post
Standoffs should only be placed where there is a hole that can receive a screw into it. Some standoffs are standard for every board and a few have variable positions. Only install the ones that correlate to your specific motherboard and remove all the others that do not match up.
450
thats what i mostly did the other 2 where there (defult for larger board) i just left them in / i didnt see it touching mobo, i thought no harm no foul.
damn electronics you tricky basterd...fool me twice , you aint gonna fool me again!biggrin.gif
post #13772 of 15526
ok its all in case works.... but without anything in mobo header
338
i tried turning on with build complete - nothing
i took power sw cord out of header tried paper clip - nothing
i took all case wires out of header/ did paperclip - works / case fans, heard hdd spin ,cpu fan and psu fan. ( nothing on moniter but i think i read i have to wake it up on key board.).
any suggestions on header / heres cords and instructions - and how i had them
338
338
338
post #13773 of 15526
Plugged in header cables all look correct, except you HDD LED will be acting as the Power LED since it is plugged into the MSG pins rather than the HD pins (unless this is what you required).
If you have access to a multimeter try checking the power switch on the case to make sure you get a closed circuit when the button is pressed. Have you tried to see whether it powers on with just the power switch header connected?
post #13774 of 15526
yeah i conclude its faulty case tried every combo on header - nothing
will email newegg for replacement
edit - should i continue with bios(i can shut down regular when windows installed correct) - or wait till new case arrives
post #13775 of 15526
Originally Posted by Dark_Slayer View Post
What you read was probably somebody using either WHS v1 pre SP1 or Windows XP x86, in which case they can't use all the available storage as one disk.
Windows 7 and WHS 2011 both support GPT formatted drives. Which is what you'll need to format these to for all 3TB to be utilized. If you connect them to your machine and don't see all 3TB available under "Properties" then follow the instructions here http://technet.microsoft.com/library/cc725671.aspx Easy peasy
Also, the "How much after format" question is about manufacturers/OS display of available storage. For over 2 decades, every OS has displayed storage in Base2. (i.e. 1024MB = 1GB). Hard drive manufacturers have been squeezing out drives in Base10 (i.e. 1000GB = 1TB). In fact, some people started trying to refer to the old Base2 GB as GiB. In other news, Apple's been using Base10 to report drive sizes since Lion, I believe. Really you're not losing any data capacity, it's just an accounting terminology. 3000 GB = 3 TB in Base10, but since the Windows OS reports storage in Base 2 (binary) then you would need 1024^4 or 2^40 bytes per Terabyte which comes out to 1099511627776 bytes, putting that back into base 10 is (3.299 x 10^12) or 3.3 TB according to Hard Drive manufacturers.
So long story short, a 3.0 TB drive will be accounted as 2.7 TB
thanks for explaining that. you dumbed it down for me wink.gif also thanks for the link. it will come in handy if i need it
post #13776 of 15526
You could plug the reset switch into the powerswitch on the motherboard and use that to turn it on and off until you replacement case turns up.
post #13777 of 15526
[quote name="kesawi" url="/t/1302559/assassins-
simple-beginner-htpc-buying-guide/13770#post_22214215"]
You could plug the reset switch into the powerswitch on the motherboard and use that to turn it on and off until you replacement case turns up.[/quote]
Tried that already
Thanks for your guys help. Now its back to waiting game
post #13778 of 15526
HDD arrived, ordered it Wednesday from AMZN, free super saver shipping.
post #13779 of 15526
I popped the drive in, however when I formatted it I show (in Disk Manager) 2048 GB NTFS Healthy, primary partition and 736.52 Unallocated... this is a 3GB drive, running Win 7x64. What am I doing wrong?
Never mind, you can not use MBR for drives larger than ... 2TB let's say (not sure of the cut off) If you do and need to reset:
Go to a command prompt (as admin, I guess)
C:... :diskpart, then from the diskpart prompt: list disk; find the number of the disk you need and then: select disk
Edited by mattiedread - 7/13/12 at 5:19pm
post #13780 of 15526
Sorry, it wouldn't take my full edit:
from a cmd prompt type:diskpart
list disk
select disk look at the list right above the prompt which appeared after executing 'list disk'
clean
convert gpt
On a sadder note, when installing the drive I accidentally yanked one of the plastic covers for a SATA 3 off my board, will try and fix in the morning (not hopeful). Goes to show Assassins advice of not using too short cables is sound; I was using 10" in a mATX build (Silverstone G5).
post #13781 of 15526
My computer won't play or even locate any of my Bluray files in WMB anymore, it says something that it can't locate the right folder or something like that. I know I read a post about this a while back, I think someone said it might have something to do with the codecs or something like that. Can someone point me to the thread or post about this topic, or any information on this matter would be extremely helpful. Thanks ya'll
post #13782 of 15526
If you were replacing an aging HTPC, would you wait for an Intel Ivy Bridge i3 or go with a Sandy Bridge i3 2105?
post #13783 of 15526
I myself would wait on the new i3's & match with the new Z77 mobo's
That way you are future proofed for years to come
post #13784 of 15526
Depends on how dysfunctional the aging HTPC is. If you can use it for a few more months then I would probably wait. But the current i3 is absolutely fine as well.
post #13785 of 15526
This is an eye opener. I nearly pulled the trigger on my equipment this weekend. But can wait a while.
I've been trying to Google around and see if I can find some sort of timeline for this, but I'm not sure what I'm looking for. I do see that new egg has some i5 and i7 Ivy Bridge but they are pretty pricy.
post #13786 of 15526
Can anyone help me out on getting WMB to recognize my Bluray MKV's? It used to, but now it says it can't find the right file or folder? I know it has been discussed here, I just can't find the correct post. Any help would be greatly appreciated.
post #13787 of 15526
IIRC this fall was to the release of the lower end i3 .
Edited by Fastslappy - 7/16/12 at 10:41am
post #13788 of 15526
here's what I could find ...3rd quarter release
http://www.cpu-world.com/news_2012/2012032702_Revised_Ivy_Bridge_launch_schedule_confirmed.html
page down for the specs & the statement on the release for the i3's
post #13789 of 15526
i3 projected prices for Ivy Bridge
the 3225 seems to be the sweet spot for a HTPC processor ,due to it being the 4000 version of Intel onboard graphics
http://www.cpu-world.com/news_2012/2012052101_Prices_of_upcoming_Ivy_Bridge_desktop_CPUs.html
expect retail to be about $20 to $30 more than these 1K tray prices
post #13790 of 15526
There have been some changes in LAV since my initial guide that make it a better option now. Shark007 and I have been discussing this most of this week.
My HTPC is about a year old and built using the paid guide back then. I haven't messed with it much since then and it's been working fine for bitstreaming the hd audio, is there any reason I would want to go in now and change stuff using this updated shark section in the guide?
Any idea if there is or will be an android tablet app that will let us control mediabrowser? Something like Constellation?
post #13791 of 15526
This is a REALLY good question all the way around ! My htpc was built back in Feb. of this year and I have not updated LAV or MB and my system still does everything I ask it to .
I would be curious to hear thoughts on this as well .
post #13792 of 15526
Further more .....
The i3 SB could ( i said could ) also drop in price once the i3 IB comes out which if your looking for a good deal on a very capable cpu then you may still want to go with the i3 SB after i3 IB comes out . If you purchase a Z68 MB then you could in theory upgrade the new i3 SB to a i3 IB with a bios update after the eol of the i3 IB is reached and Haswell comes out .
WOW that was a tongue twister !!
post #13793 of 15526
I'm looking to build my first HTPC shortly and had a few questions. First let me preface this by saying in addition to this being my HTPC / Media server, it will also serve as my main PC (basically replacing my current PC with a HTPC). I don't play games, but am looking to build something that is powerful enough so it will be plenty fast for years to come.
Here are the main components I'm looking to buy:
Curious what your thoughts are for this setup? This may be overkill, and I was looking at the i5 3450 ($149 at Micro Center), but Micro Center has the 3570 on sale right now for $189, and with that processor I can get $50 off the motherboard, so it ends up being $10 cheaper then just getting the 3450 without the bundle deal. The P8Z77-V LX is on sale for $124.99, or $74.99 with bundle deal. Main thing I like is having true quad core rather then multi thread 2 core. Plus it can handle the 1600 mhz ram, where Sandy Bridge i3's won't. So my thought is I'm getting more then I need, but with 1600 mhz ram, a true quad core processor, and with Windows 8 supposed to be able to fully utilize multiple cores, I should have something that won't be outdated from a performance perspective and I'll be happy with in the long run. My current Dell I want to hurl out the window (no pun intended) most days.
One thing I noticed is the case has 4 x 120mm 4 Pin MOLEX fans (one with blue LED), and the mb has 2 x 4-pin chassis fan leads (in addition to the CPU fan lead and a 3-pin power fan). I've read there are a few options in this situation (more fans then mb leads) and was wondering what your experience is or what you recommend?
  • Wire them to the PSU, they will run 100% all the time (not what I want)
  • Buy Molex - 4 pin converters and connect 2 fans to the mb leads, then if i want to connect other 2 they would need to go to the PSU
  • Can you connect multiple 4 pin fans to a single mb lead? 2 per lead would support all 4 case fans
  • I thought I read where there is an adaptor that connects the fans to the PSU, and some lead wire also goes to the mb, so the mb can control and monitor the fan speed, but the power is supplied by the PSU. Is this true? Any one do this? Following is a link: http://www.frozencpu.com/products/10350/cab-183/Akasa_PWM_Splitter_-_Smart_Fan_Cable_AK-CB002.html
  • Buy fan controller (again, would like to avoid this)
Ideally I don't want to have to buy a fan controller, and don't want them running 100% all the time either. Like having the mb be able to monitor and control speed of the fans. I'm not sure what power the mb 4-pin chassis fan leads are, however what i've read is most should be plenty powerful enough to power 2 (prob not more then 2 though) fans per lead. Any ideas/suggestions or knowledge you can share with me would be greatly helpful.
Thanks for your help, I appreciate all the helpful knowledge and answers this forum and all its members provide!!
Edited by bobby2478 - 7/16/12 at 3:48pm
post #13794 of 15526
  • Ivy Bridge i5 3570k
  • Asus P8Z77-V LX 155 ATX
  • 128GB SSD (haven't decided model yet)
  • 500w Power Supply (haven't decided model yet)
  • Diablotek EVO CPA-6170 Case
  • 8 GB GSKILL Ripjaws (2x4GB) DDR3 1600 (PC3 12800) Memory
  • 1 TB WD Caviar Black HDD (currently in my existing PC)
  • Will upgrade to Windows 8 once available this fall
that mobo has a fan control software in the bios
if you are not gonna over clock the CPU then don't get the "K" model CPU the non "K" has more features
that mobo has about 4 or more fan headers on the PCB & they are 4 mini pin headers as well soo i'd replace the fans with silent cougar 4 mini pin fans (pm me i'll link them ) I run all fans off my Asus Z77 deluxe & I use a Antec 300 case , I replaced all the case fans with 4 mini pin Cougar silent models
Edited by Fastslappy - 7/16/12 at 3:57pm
post #13795 of 15526
Thanks for the info. The CPU is listed as the 3570K Unlocked*, so am I wrong to assume the "unlocked" version would have more features then the "locked"? Unless CPUs are different then mobile phones and other areas where "unlocked" = more features. Also I won't be overclocking anything, as I'm not gaming there won't be a need to overclock. The only Ivy Bridge processors I see listed with Micro Center are:
  • i5 3450 ($149.99), no motherboard bundle discount
  • i5 3570K Unlocked* ($189.99), plus $50 bundle discount off motherboard
  • The others are both i7's, which is more then I need
So initially I was just going to go for the 3450, but since that isn't eligible for bundle discount whereas the 3570K is, I'm still saving $10 over buying the other processor and paying full price for the motherboard. That's the only reason I bumped up to the 3570K from the 3450, is it works out to be $10 cheaper when I buy the motherboard at the same time.
The mobo only has 3 x 4-pin fan connectors, and one is for the CPU, so only 2 x 4-pin case fan connectors and 1 x 3-pin power fan connector. Since 4-pin is required to control speed, the 3-pin would need to run at 100%, in which case I might as well go straight to the PSU. I'm looking to keep the price of the overall kit as low as possible, so I'd like to not have to replace the fans since the case includes 4 fans already, and I figure since they are there I might as well use them. The feedback on the case says the 4 x fans are all 120 mm and have the 4-pin MOLEX connectors, so others were having to get an adapter to hook up to their mobo if they wanted variable fan speed without a seperate controller.
Edited by bobby2478 - 7/16/12 at 4:24pm
post #13796 of 15526
as strange as it sounds the unlocked has LESS features
post #13797 of 15526
Ok, thanks. Knowing that, my options are:
  • i5 3450 ($149.99 at Micro Center), ASUS P8Z77-V LX ($124.99 at Micro Center), Total = $274.98
  • i5 3570K Unlocked ($189.99 Micro Center), ASUS P8Z77-V LX ($74.99 w bundle discount at Micro Center), Total = $264.98
  • Newegg = i5 3570 ($214.99), ASUS P8Z77-V LX ($124.99 at Micro Center), Total = $339.98
So as you can see, by going with the 3570K version at Micro Center, I save a total of $75 on combo of CPU and mobo vs buying the 3570 at Newegg (MC doesn't carry this version). So is it really worth paying an extra $75 to have the same processor with more features? Would I be better off with the i5 3450 instead of the i5 3570K? If I went with the 3450 instead of the 3570K I'd have to spend an extra $10 for a slower CPU, which would still be $65 cheaper then buying the regular 3570 from Newegg.
Also on Toms Hardware forums they say the only difference between a "K" processor and the "Non-K" version is that you can overclock the K more then you can the Non-K, but other then that they don't note that the K version is lacking anything the Non-K has.
Micro Center ONLY carries the i5 3450 and the i5 3750K Unlocked, they DON'T carry the regular 3750. And their prices are by far better then Newegg or anywhere else online at the moment.
Edited by bobby2478 - 7/16/12 at 5:10pm
post #13798 of 15526
Hello, I'm attempting an HTPC build and need advice.
Should I use a separate power supply cable for the hard drive and the SSD, or should I try to connect the single power supply cable to both? As it's laid out now one single cable isn't long enough to connect them both.
My case is a Silverstone GD04 with a GA-Z68 MB and Silencer MK III power supply.
448
Also, Assassin you mentioned you modified the adapter which combined all three case fans into one connection. I'm not knowledgeable in that area. With the cable supplied I don't see where this attaches to on the motherboard. Is there another cable that I need to get?
448
post #13799 of 15526
448
448
If the adaptor you're showing is for your case fan, then it looks like it's a larger MOLEX connector where the mobo uses a smaller connector, in which case you would likely need an adaptor or else go straight to the PSU. I have a similar question about hooking up case fans to the mobo when you have more fans then slots on the mobo. If the case fan adaptors are all 4-pin, then you can control the speed. If they are only 3-pin, then you can't (4th pin allows speed control), and it would run at 100% all the time, in which case you may as well go straight to the PSU anyway (which can handle MOLEX without an adaptor).
post #13800 of 15526
These definitely aren't 4 pin adapters so I guess the case fans will run constantly. Is that ok? Won't that make the HTPC much louder?
Anybody else here have a GD04 case with a GA-Z68MA motherboard?
