AVS › AVS Forum › Video Components › Home Theater Computers › Assassin's Simple/Beginner HTPC Buying Guide
Assassin's Simple/Beginner HTPC Buying Guide - Page 473
post #14161 of 15525
I was not sure who to contact but everytime I try to access the guide I get this error:
503: Service Temporarily Unavailable
Too many IP addresses accessing one secure area!
Please contact Support if you need assistance.
Has been happening for the whole week now. Was able to use it before with no issues.
post #14162 of 15525
^I believe you can't log in in from multiple computers in a certain time span. not sure of the exact amounts though.
post #14163 of 15525
I have a simple request hopefully:
I purchased Assassin's HTPC guide and will be building my first HTPC some time next week. I could not locate any guides speaking about networking. Basically what I would like to do is rip/download BD movies on my existing desktop and send them to my HTPC. My HTPC will be located in my dedicated theater room and turning on the projector every time I want to work on the HTPC is a bit impractical. Any simple solution to network my existing computer and my HTPC together? Both are Windows 7 machines.
Edited by azula - 8/17/12 at 2:50pm
post #14164 of 15525
PM me your user name. I don't have a "phdhusky" in my database.
BTW only 5 IP addresses are allowed per account.
post #14165 of 15525
Do you have wired network?
I am confused in what you mean. Its just like setting up a Windows HomeGroup since you have 2 windows machines.
post #14166 of 15525
From DealNews:
TigerDirect offers the TRENDnet 500Mbps Powerline AV Ethernet Adapter Kit, model no. TPL-401E2K, for $49.99 plus $2.99 for shipping. That's tied with our expired mention from three days ago and the lowest total price we could find by $7. This plug-and-play Ethernet kit uses your existing electrical outlets to create a secure 500Mbps high-speed building-wide network.
post #14167 of 15525
Simply connect your new HTPC tou your existing network, join your Windows Homegroup and share whatever drive or folder you want to save your rips in. Then on your desktop when you are done ripping a movie, open the shared drive on the HTPC through explorer on your desktop, cut & paste, done.
post #14168 of 15525
Thanks Lastbutnotleast, I already have the powerline adapters which are working great! I just needed to figure out how to network my computers so that I can transfer files. Assassin and wilky answered the question for me. Doing some research on homegroup sharing now. Thanks!
post #14169 of 15525
Originally Posted by cyberguy34 View Post
I stand corrected. You may be correct on the 29/59 bug. I didn't know the "white flashing" was also a symptom of it. I only thought the stutter or skips were the 29/59 bug. This is a letdown. Hmmmm, well time to start messing with driver and configs to find a work around....
I found a solution to my 29/59 bug. I can only confirm this fix with the Intel i3 HD2000 GPU, running the latest driver.
Launch Intel Graphics > Use the Advanced option > Media > Image Enhancement > Make sure EVERYTHING is checked off in there. Apply. FIXED!
This only corrects the "White Flicker" not the actual frame rate issue, but most if us can't even noticed it. Its the flashing that was very painful. Hope this fix works for anyone running i3 chips.biggrin.gif
post #14170 of 15525
I was under my DISH account adding a few things and seen they had a OTA module. Not sure if it's new or something they had for awhile, but I was wondering if I purchase it, if I would be able to watch and record TV through my HTPC? I know while following the guides a few months ago it looked like Cable subscribers could do so, but it didn't seem like DISH or DTV customers could quite do so. If I can do it, is there anything else I should know as far as software and hardware? Is it worth running through my HTPC or should I just use my 722K receiver?
Judd
post #14171 of 15525
Hoping someone can help....
The pieces to my HTPC have started to arrive. I have been looking at them as they come in, and the SSD didn't come with any cables or adapters to install it into the HTPC. Is this something I need to order before I can assemble, or does the motherboard have the necessary parts to connect it?
post #14172 of 15525
Your mother board will come with way more (most of the time) sata data cables than you will most likely ever use . Your power supply will come with the sata power connections that you need
Most ssd do not come with adapters to reduce there size to fit in a 3 - 1/2" drive bay . The Samsung ssd do come with them . You can do a search for the adapter for your drive or you can do like the rest of us and Velcro it in a nice secure location and rock on !!
WELCOME to the forum
post #14173 of 15525
Thanks much flocko!
I'm starting to get nervous about the build. I've added memory and a new DVD burner to a retail pre-built PC before, but I've never built one from scratch. Was really hoping that Assassin's guides would help me with some of this, but I can understand why they do not.
Hopefully I'll be able to get some of the help I need here and find the rest with my good buddy Google.
From you last bit of advice, I take it the SSD doesn't have to go into a drive bay? Great! Will make sure I have a roll of Velcro on hand before I start. Is it pretty obvious where all the rest of the components go?
Matt
post #14174 of 15525
Thanks much flocko!
Matt
Matt - Don't be nervous. The hardware portion is by far easier than the software setup. There are a ton of youtube videos, guides (see my FAQ for a link to one I like) that can help you.
The SSD does not need a drive bay. No moving parts and no heat mean they can go just about anywhere. I have used velcro with sticky tape on the back of each side many times. As far as where everything goes look at your case manual to help show you. I can't do step by step hardware guides because there are so many different cases, motherboards, etc and it just isn't feasible.
BTW most motherboards come with 2 SATA cables. So if you need more plan accordingly.
post #14175 of 15525
Awesome! Thanks Assassin! Just found the Tom's Hardware link in the FAQ2. Hopefully that will take care of most of my building questions.
Do I want to setup Mediabrowser, XBMC, and Plex if I want the most compatibility with Android/iOS devices including controlling of the system?
Matt
post #14176 of 15525
Matt
Xbmc, imo.
post #14177 of 15525
Thanks much flocko!
Matt
This is a step-by-step guide on how to put together a PC: http://www.tomshardware.com/forum/274745-31-step-step-guide-building
post #14178 of 15525
Is XBMC preferred if you are just wanting to view videos? I would like to switch completely to XBMC but since I use WMC for liveTV I can't make the switch completely.
Is it possible for XBMC to handle liveTV now? I am using an HDHRP with TWC as my provider (copy protected content).
post #14179 of 15525
Not with the Prime.
post #14180 of 15525
Thanks for this tip.
What resolutions do people set in MadVR? My display can handle 24hz but right now I only have 1080p/60. Should I put 1080p/24? Any other resolutions I should put on there? I have a i3-530 (HD2000?) and I stream a lot of blu-ray rips.
post #14181 of 15525
Every resolution that your HDTV can support and any custom resolutions you may have created if you have the ability to create them.
post #14182 of 15525
Thanks for confirmation on that.
BTW, should I change the settings on MadVR from what Assasin recommends for scaling algorithms since I'm using HD2000 iGPU:
Chroma=Catmull-Rom;Luma Upscaling=Soft Cubic (50); Luma Downscaling=Soft Cubic (50)
I am noticing some vertical white lines when watching videos in mpc-hc. They aren't entirely noticeable from a distance but can be seem if you look close at the screen. I have also unchecked 'exclusive mode' in madVR.
UPDATE: From reading other threads some say the HD2000 can't handle madVR and some say it can. I do have my GTS450 lying around that I ripped out to use the iGPU of my i3 instead. I guess I can just pop it back in as I have resolved my bitstreaming audio issues. I have an Asrock H55M-Pro and this has only 2 PCIe x16 slots and I am not able to use my PCIe x16 (x16 mode) slot anymore as I just installed an Intel NIC in my x1 slot. Since my GTS450 takes up 2 slots I will have to use my PCIe x116 (x4 mode) slot instead. Will I see any performance hits using this slot?
EDIT2: I found a nice chart that shows there won't be much of a performance hit if I use the x4 slot so I'll be good to go. Now to install that beast back in.
BTW, is there a good program to control the fan speeds of gpus? I'd like to keep the fan on the GTS450 as quiet as possible.
Edited by utee05 - 8/20/12 at 10:54am
post #14183 of 15525
Update: Ended up with 4 x 3TB Western Digital Reds (completely overkill). I went completely overboard with my build. Probably could have spent half of what I did. Anyway, installed FlexRAID last night (Thanks to Assassin's paid server guide). All is well, just need to tweak a few things in XBMC and wait for my N5902 remote to show up.
Originally Posted by pbmpharmacist View Post
This post is a rambling mess, but please bear with me. Now that I've ripped a ton of media, I'm paranoid that if a hard drive crashes that I'll lose it all.
What kind of hard drives/ internal storage are you guys using? Anyone using FlexRAID? I've now ripped over 3 TB of data and I'll probably be at about 3.5 TB when I'm completely done. The thought of losing that data makes me physically ill as I've been ripping for about 10 days now and I'm not even done yet. Right now, I have 2 Seagate 3TB ST3000DM001 drives because the reviews are decent and they are pretty cheap. But I read on slickdeals that the "power on" stats for that drive suck, that if you ran it 24/7 that it would die in 4 months. That's probably why they only have a 1 year warranty. Anyway, I'm thinking of returning them to Amazon and buying 4 Western Digital Black 2TB WD2002FAEX drives for the 5 year warranty (I don't care about the 7200 speed, I just care about the warranty and perhaps better reliability). I could use FlexRAID to spin them done when they are not in use.
Anyway, I'm just confused about how many hard drives I'd need to back up all of my data. If I have 4 TB of data (I'm probably rounding up here but better to estimate high) and I use FlexRAID, how much data space do I need to back up that 4 TB? Another 4 TB?
Also, should I ditch the Seagate 3TB ST3000DM001 drives? Should I get Western Digital black drives (2 TB) ,WD green drives (3 TB, 3 year warranty) or red drives (3 TB provided I can find them, 3 year warranty)? So many options and all of the user reviews suck for big hard drives!
post #14184 of 15525
While I'm thinking about it, what's everyone's favorite XBMC skin? I've looked at some of the screen shots from Assassin's paid site. Also I've looked here: http://www.makeuseof.com/tag/6-coolest-free-skins-xbmc-media-center-si/
Thinking of installing Quartz because of how easy it is to use for my family (I'm not crazy about it though). Any thoughts?
post #14185 of 15525
To anyone still on the fence about a HTPC and building one yourself using these guides,
My wife and I got tired of the bait and switch tactics our cable TV / internet provider kept pulling forcing us to pay for ridiculous packages for the very few shows we were interested in watching so we decided to pull the plug on them for the TV service and go with a combination of over the air, Netflix, and internet TV via a HTPC. We have piles of music CD, DVDs, and Blu Ray discs here and were obviously intrigued by the capability to keep the physical discs safe while we enjoyed their content as often as we liked via Media Browser and WMC. We looked at buying a purpose built HTPC but none really offered the value or specific features we wanted so we looked into building our own. Like you we searched for HTPC build instructions and found this wonderful guide. We read the guide three times to make certain that we understood it and then took the plunge using the Sandybridge instructions. The only changes we made were to use 16gb of ram - by using a huge coupon we had found - and upgrading the CPU to the i5 variant to add the extra cores which have aided us in ripping our music and video discs but speeding up the process. When looking at over three hundred DVD's and nearly a thousand music CDs the additional power to speed those process up were greatly appreciated. We used the 65gb SSD for the primary system drive and three internal 2tb drives for video media storage. I have an external 2tb USB drive here that we are using to keep our music on for the time being but may change that out at a later date.
At first sight when all the parts showed up I was a little disconcerted that maybe I had bitten off more than I could chew but using the guide and other tips from AVS Forum members I got it up and running and installing Windows with ease. I was actually terrified that it had gone too easy and that I had certainly overlooked something or made a grave mistake. My fears abated once I got the Media Browser software installed and got the plugins for WMC added that I wanted to try. I had already started to make copies of our DVDs and storing the output onto another PC in the house so after added the new HTPC to the homegroup and setting the share properties the movies were on the move to their new home.
Obviously we fumbled around a bit as our TV experience had changed but once we found more and more features we really enjoyed our HTPC more and more. We built ours about a year ago using this guide and I can say now that if we were to go back we would suffer considerably as the HTPC just makes sense in so many ways. Eventually we will add a media storage server and build a smaller HTPCs for the master bedroom. When the time comes I fully intend to make use of these guides again as while they were a bit large to take in all in one setting they made the process painless and much more affordable than if we had opted for a pre-built unit or just picked parts that we thought would work out for our needs. With that said, thanks to Assassin and everyone else here that shared their time and knowledge as through you our TV experiences have become more entertaining and much more affordable as well. Doing the math after cutting the cable TV service off and changing our cable internet service to a business account instead of residential - faster speeds and guaranteed uptimes - we broke even five months ago via our purchase invoices and the HTPC is saving us right at around $120.00 every month.
If you are here then you have already recognized the benefits of a HTPC, so go ahead and go for it as I honestly don't see how you will dissapointed. And thanks again to Assassin and all the others that have shared so much with us. I for one, am very grateful.
post #14186 of 15525
NOT overkill IMO. I went with the best I could get at the time and what Assassin recommended. After only a few short months I filled up 4 TB's and had to source more. You'll be ok with 12TB's for a little bit smile.gif
post #14187 of 15525
It is possible to add a "button" to WMC to access XBMC, see here:http://xbmcwmc.teknowebworks.com/.
post #14188 of 15525
Awesome! Thanks for using the guides. Hope you are enjoying the new server!
post #14189 of 15525
What a great write up. Thanks for taking the time to post your thoughts and experiences. I know that others reading it appreciate it.
post #14190 of 15525
I am, thanks to you!. It's really more of an HTPC that happens to be running FlexRAID.
